Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to use PBR textures in Arnold for Maya
When downloading textures for Unity or Unreal it seems very difficult to get them to work with Arnold. Has anyone found a simple way to create nice looking shaders with these maps?
When simply plugging in the albedo to base colour, metallic to metalness and roughness into the roughness slot the result are very different from what you'd expect.
lee_griggs
Here are a couple of PBR workflow tutorials.
https://www.youtube.com/watch?v=kgiZ-ZOEPNg
https://www.youtube.com/watch?v=qXv2ag60FiA
For Specular Roughness, connect a Range shader inbetween the map and the Standard Surface. Example here.
Lee Griggs
Arnold rendering specialist
AUTODESK
giandosopaolo
Hi @Lee Griggs.
Is it just enough to add a range shader inbetween and leave it there or its parameters need to be adjusted in a specific way? What is the purpose of the range node?
Many thanks
Paolo
lee_griggs
You don't have to. It just gives you extra control. Example here.
Otherwise, just connect the images outR -> Specular Roughness.
Lee Griggs
AUTODESK
aiRange is extremely awesome. It took me some time to get my head around the node, but since I know what it's doing exactly, I am using it on a regular basis when I shade. It's super conveniant to adjust black and white values for roughness-, bump- or displacement maps without leaving the hypershade, perfect for your LookDev-needs with any textures.
aloedesign
What I found was that I needed to tick the "alpha is luminance" box in the metalness file node, and then things started to look like PBR what I expected.
