How to handle transparent map? I've tried several times but not successful
result:
my demo file:
egg.zip
madsd
Try something like this.
I just used a planar UV map on the model instead of 2 material ID's to avoid having to deal with ID's but you can use ID's in a single material anyways with a switch map in addition if you realy need 2 ids.
madsd
Another variant with Material ID's
Saved to 2019 and attached.
4389-q.jpgegg.zip
Thank you very much, I like this method and I do it following your screenshots, the result is as follow:4392-snipaste-2019-08-16-22-29-36.png
How to set the parameters of "uvw map"?
@Mads Drøschler
if I want to use unwrap UVW modifier instead of UVW Map, how to do it? Do I need to modify material setup?
madsd
madsd
Not realy no, you can however use the UV transform node to adjust some local unwrapped tile, just note that everything inside the same UV channel is affected by the changes in the shader hirachy, you would have to isolate a certain area if you want independant control.
However, if you unwrap the head and give some polygon square a material ID 2, you can call this ID 2, as seen in the variant solution just above ( purple head ) and that can both be planar map, or advanced UNWRAP or whatever realy.
