How can I hide the Skydome light in the view port and still have it affect the render?
lee_griggs
Autodesk Autodesk
Message 1 of 15
lee_griggs
Lee Griggs
Arnold rendering specialist
AUTODESK
Replies (14)
Message 2 of 15
lee_griggs
You can set the Sky Radius to 0 in the Viewport attributes of the Skydome light. An easier thing to do is add the following to a hotkey:
setAttr "aiSkyDomeLight1.skyRadius" 0;
As this is a frequently asked question we have provided both the question and answer in this thread.
Lee Griggs
AUTODESK
Message 3 of 15
Michael_Todd
You can also not show lights in the VP.
Michael Todd
XGen Product Owner and Designer
Message 4 of 15
ece3k
This worked to hide the sky dome in the viewport but it still rendered for me in the renderer.
How do we see it in viewport but it doesn't visibly render as a background?
Message 5 of 15
lee_griggs
You can disable Camera Visibility.
Lee Griggs
AUTODESK
Message 6 of 15
darioOrtisi
@Lee on the transform node of the Skydome. "Display" set LOD visibility to off(flag check off)
Message 7 of 15
It depends on what renderer you are using, I'm going got assume that you are using Arnold, select the skydome light and then in attributes section find the 'Arnold' section and set the 'Camera' scroll bar to 0. This will prevent Arnold form rendering your hdri in the view but it will still be used to light the view. Hope it helps : )
Message 8 of 15
l.croisez
Community Visitor
Community Visitor
Kevin je t'aime
Message 9 of 15
ahmed_awad
Change Value of Camera from 1 to 0
Message 10 of 15
lee_griggs
That actually hides it in the render. Setting the sky_radius to 0, hides it in the viewport.
Lee Griggs
AUTODESK
Message 11 of 15
a.mansour.vfxcomp
I had to sign up only to give you a thumb up
Thank you so much
Message 12 of 15
luisandro.garza
under the light shape, under visibility turn the camera to 0 and the background won't render.
Message 13 of 15
LeslieHe
Thanks, it worked.
Message 14 of 15
luisandro.garza
Glad to help.
Message 15 of 15
zoharl
display> object display> template
Edit: doesn't render..
