Help, Arnold doesn't render Maya shaders in Maya 2018
Message 1 of 10
2231-screen-shot-2018-08-23-at-121949-am.pngHi all. I'm having issues with Anorld to Maya 2018 renderer. I created an eye and textured it with Maya ramp and noise shaders. I also created an outer eye and made it transparent. This renders correctly in Maya renderers. But when I rendered using Arnold, the ramp and noise textures do not render. How can I fix this please?
NB: I've attached pics of the renders below. The picture showing the eye textures was rendered with Maya renderer while the other was done using Arnold.
Replies (9)
Message 2 of 10
lee_griggs
What shaders are you using?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
Slava_91
It seems you forgot to tune your glass shader(Cornea) on the eye
Message 4 of 10
lee_griggs
Also, remember to disable Opaque and enable Caustics for the outer cornea shader.
Lee Griggs
AUTODESK
Message 5 of 10
Thanks @Lee Griggs. I turned off opaque for Arnold under the Outer Eye mesh Attribute Editor. I used Maya shaders before and it didn't work. Using Arnold surface shader solved the problem. I guess Arnold doesn't recognize Maya ramp and noise shaders.
Message 6 of 10
Didn't use glass shaders. Just ordinary Maya Lambert with transparency turned on.
Message 7 of 10
lee_griggs
Maya ramp and noise shaders should work fine. How was you using them?
Lee Griggs
AUTODESK
Message 8 of 10
I created materials for the noise and ramp shaders each. Then I created a Layered texture and connected both noise and ramp materials to it. Then I applied the layered texture to the eye. It rendered fine using Maya renderers, but Arnold wouldn't have it.
Message 9 of 10
with Arnold shaders it finally rendered
Message 10 of 10
lee_griggs
Great! MtoA also has its own layered shader, layer textures and mix shader.
Lee Griggs
AUTODESK
