Emission in standard surface
rico
Message 1 of 11
rico
Sometimes I have to use the emission in set standard shader to light a part of the scene. Then it males no difference to set the emission to 100 to to 1000. It's not getting brighter. Is there something limiting the emission of the standard shader on higher values?
Replies (10)
Message 2 of 11
rico
Can someone help? Maybe I don’t have explaind my problem well.
Message 3 of 11
Stephen.Blair
The surface itself should be getting "brighter"
The pixel values on the surface will be way over 1,1,1
Other objects in the scene use diffuse (indirect) sampling to get a contribution from the emissive surface, and that is clamped to 10 by default.
// Stephen Blair
// Arnold Renderer Support
Message 4 of 11
rico
Is this the setting for clamping diffuse samples? By default it's switched off. Or is there another setting?
Message 5 of 11
Stephen.Blair
The UI control is disabled, so you get the default of 10
if you want a different value, enable the UI and change the avlue.
// Stephen Blair
Message 6 of 11
rico
Thank you. This hint is very helpful.
Message 7 of 11
rico
I did some tests and I changed the indirect sample clamp. But the brightness of the emission does not change.
Message 8 of 11
rico
Here I set the emission to 100 an the sample clamp to 1 and 100. There is no difference in brightness.
Message 9 of 11
peter.horvath6V6K3
There's a bug in the plugin and the indirect clamp is not exported properly now. It's gonna be fixed in a next release.
Message 10 of 11
Stephen.Blair
User options workaround:
// Stephen Blair
Message 11 of 11
peter.horvath6V6K3
As a workaround you can set the indirect_sample_clamp as a user option in the render settings:
