Cant assign Object ID´s
Message 1 of 24
I´ve asked this question earlier but I try once again:
I want to assign object ID´s to some objects.
I´ve tried a lot but I can´t manage to get individual colours on the objects when rendered.
So thankful for help!
Thank you in advance.
Br Marcus
Replies (23)
Message 2 of 24
lee_griggs
Which plugin? Have you tried the ID AOV and/or Utility shader?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 24
Actually i don´t know exactly which Plug-in I Use. I haven´t download any so to say.
Under the "built-in rollout" I´ve used both the "object" and "ID", I think the problem is that I don´t know how to choose and assign ID´s to the specific objects.
/ Marcus
Message 4 of 24
lee_griggs
MAXtoA? You can download the latest version of the plugin here.
Tutorial here.
AOVs
Utility shader
Lee Griggs
AUTODESK
Message 5 of 24
Yes I have MAXtoA plug in.
Message 6 of 24
Which of the AOV, in the builtin rollout are the best to use if I only want to "separate" some of the objects from the others? (in the render with different colours) And how can I assign it to the specific objects?
So thankful for your help.
Marcus
Message 7 of 24
lee_griggs
Did you try the aov_write_rgb as in the tutorial?
Lee Griggs
AUTODESK
Message 8 of 24
I try now and I think everything is fine, until I should "Open the Render Settings window and under the AOVs tab, select 'Setup AOVs'". I cant find the setup AOV tab.?
But I can see that I have the "ObjectID" under the custom rollout.
Therefore, How can i move forward and assign it, You with me?
Marcus
Message 9 of 24
Hello Again,
After looking at the Tutorial, They are not showing how to assign the object ID´s, Will arnold do it automatically?
Br,
Marcus
Message 10 of 24
lee_griggs
Have you tried ID AOVs in the Standard Surface?
Lee Griggs
AUTODESK
Message 11 of 24
When i look in the standard surface, I can´t find the AOV rollout in the bottom.
Everything else is exactly the same, but I miss the oppurtunity to choose "colourID"
I can add to the conversation that i´ve used the Arnold material, Is that a problem or could I still render Object ID?
Message 12 of 24
lee_griggs
Have you installed the latest version of the MAXtoA plugin?
Lee Griggs
AUTODESK
Message 13 of 24
I will install it and check, Hopefully it´ll help me!
Message 14 of 24
I´ve now downloaded the plug in and got all the functions as I need.
My Question is right now: How do I compare the different ID´s (in the rollout where I can choose colours) with the objects I will pick pick in the render set-up window. (Where I add Custom AOV´s)
Message 15 of 24
lee_griggs
You can assign different Standard Surface shaders to different objects with different IDs. The workflow is here.
Lee Griggs
AUTODESK
Message 16 of 24
Okey. Just to ensure: In The standard surface rollout, i write ID1 with pink colour, Then in my Custom AOV I create a new AOV called ID1, I add it to the object i want to have an Object ID on, I press add " channels" , Is that workflow right and can i expect it to render out the objects with dif. colours?
Message 17 of 24
lee_griggs
Yes, but you set the color yourself. Maybe Cryptomatte is more suitable for your needs?
Lee Griggs
AUTODESK
Message 18 of 24
Yes, The problem is that I don´t know if it generates the AOV´s since i can´t see them in the render, but i got files like .AOV in my output..
Message 19 of 24
It Seems that the Cryptomatte works good, that gives me separate colours for the objects I want. !
But i´m still unsure how to do the render process, in case of both get the "cryptomatte" separation and the "proper" look..
Message 20 of 24
lee_griggs
"and the "proper" look.."
Do you mean the RGBA AOV (beauty)?
Lee Griggs
AUTODESK
