Can't import arnold module with Python 3
With Arnold 5.2.0.0 that ships with Maya 2017, the following code works with Python 2.7 but fails with Python 3.6:
import os
import sys
sys.path.insert(0, 'C:/solidangle/mtoadeploy/2017/scripts')
os.environ['PATH'] += ';C:/solidangle/mtoadeploy/2017/bin'
import arnold
print(arnold.AiGetVersion())
Here's the output with Python 2.7:
['5', '2', '0', '0']
and the error with Python 3.6:
Traceback (most recent call last):
  File "D:\temp\test.py", line 7, in <module>
    import arnold
  File "C:/solidangle/mtoadeploy/2017/scripts\arnold\__init__.py", line 6, in <module>
    from .ai_color_managers import *
  File "C:/solidangle/mtoadeploy/2017/scripts\arnold\ai_color_managers.py", line 7, in <module>
    from .ai_nodes import *
  File "C:/solidangle/mtoadeploy/2017/scripts\arnold\ai_nodes.py", line 9, in <module>
    from .ai_universe import AtUniverse
  File "C:/solidangle/mtoadeploy/2017/scripts\arnold\ai_universe.py", line 7, in <module>
    import ai_nodes
ModuleNotFoundError: No module named 'ai_nodes'
This is caused by this `import ai_nodes` statement.
Interestingly, Arnold 5.1.1.1 does not have that statement and consequently the sample code works fine with Python 3.6.
Sorry for the formatting but the text editor is extremely buggy...
Stephen.Blair
In ai_universe.py, change line 7 to this:
// Stephen Blair
// Arnold Renderer Support
@Stephen Blair: That's not enough as the code references the ai_nodes package name later on, for instance
return NullToNone(func(universe), POINTER(ai_nodes.AtNode))
in `_AiUniverseGetOptions()`. Removing all `ai_nodes.` prefixes appears to solve the problem.
@François Beaune I solved it by changing line 7 in ai_universe.py to this, you'll have to ensure arnold is apart of your PATH environment variable:
from arnold import ai_nodes
