Can not get Lee's new refraction face tutorial to work
Message 1 of 14
Replies (13)
Message 2 of 14
lee_griggs
What is the issue that you are having Louis?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 14
The plane does not seem to refract or be transparent at all and following your directions as best I could, the image is always greyscale on the plane
Message 4 of 14
ashley.handscomb.retallack
Have you set the transmission up on the plane?
If you are not using the latest Arnold (5.3) you will need to make sure opaque has been unchecked on the plane
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
Message 5 of 14
I had not made the upgrade to 5.3 and I had set the transmission as Lee stated to 0.9. IS it possible that it is not working because of not using the 5.3 GPU version?
Message 6 of 14
lee_griggs
Can you upload the scene and I will have a look at it.
Lee Griggs
AUTODESK
Message 7 of 14
I will try Lee but that was stopped before when I tried it saying the file was too large and not a jpg or tiff etc
Message 8 of 14
I have tried but the system will not let me upload my file, where and how can I do it, it is not a picture file and it is over the size limit for the files in here
Message 9 of 14
lee_griggs
You will have to upload it elsewhere like G-Drive, Dropbox etc and post the link here.
Lee Griggs
AUTODESK
Message 10 of 14
Message 11 of 14
lee_griggs
You need to select the RenderCam in the Camera attribute of the Camera Projection.
Lee Griggs
AUTODESK
Message 12 of 14
Using the file you sent, just loading texture, I only get greyscale with no textures
Message 13 of 14
lee_griggs
I don't understand. Did you open a file texture in the image shaders? Here is what I sent you using my texture.
Lee Griggs
AUTODESK
Message 14 of 14
Thank you so much Lee, got it working with your help...I found it is very particular to the texture you use too
Thanks again
