Camera space ramp
Camera space ramp
ihabali
Camera space ramp
ihabali
Is there a way to setup a ramp using camera position information? this would basically be similar to the way 3D gradients work from the native C4D gradient shader when setup in camera space. This is also effectively depth pass, but I would like the depth information to drive additional parameters in an Arnold shader network.
But the existed depth Aov gives the desire information all the time.
zenop
One way would be to parent constrain a place3dTexture node to a camera, then scale that up to fit the bounding box of your scene and use it in planar projection mode.
ihabali
These nodes are not available in C4DtoA but I like the idea of using camera projection.
caca_caca
I'm interested in that topic as well,
I'd like to make a texture appear based on the distance to camera.
Is it possible for someone to explain in details the steps ?
Chromi
