Arnold Volume Renders as a Solid Block
syndicate5
syndicate5
Im using Arnold in Max 2017 to render an open vdb volume and I cannot get it to work!
https://www.instagram.com/the_3rdkind
madsd
If you can, try attach a max file and a single .vdb unless it is giant.
You may have to change your padding or ray march steps or call some channels on the volume via a material hook, or you have done so and you are displacing way beyond padding.
lee_griggs
Try the scene in this tutorial (and check out the other volume tutorials) to see how it works.
Lee Griggs
Arnold rendering specialist
AUTODESK
