Arnold Viewport rendering - crashing constantly
bazuka666
bazuka666
Guys i have just downloaded the latest mtoa 3.0.1 and wanna to give it a try and see how Arnold Viewport works, but i couldnt, coz every time when i switch to Arnold render view maya crashes??
Anyone else has the same problem?
I found that I could get it to work better if I rendered a Arnold Render View first, then closed that and turned on the viewport render.
bazuka666
I think i tried everything, even to hit render/arv but still no way to activate view render, like i said the moment i activate the view the exact moment maya crashes... Btw im using maya 18.3, win7 if this matters to fix the bug with viewport render
bazuka666
So will anyone from support check this bug or we are gonna just chat here about it?
lee_griggs
This is a known issue and is being worked on for a future release. Thanks for your feedback!
Lee Griggs
Arnold rendering specialist
AUTODESK
bazuka666
Thx for reply Lee, hope you can fix it asap
Cheers
salnikovsales
Observer
Observer
Hi @Bazuka Baz, i faced the same problem and it seems crashes on working with scenes which were made with older Arnold version. But if you will import older scene in new it works fine.
