ARNOLD RENDER VIEWPORT ISSUE
bhavinbarbhaya60
bhavinbarbhaya60
Hello, I have purchased maya, and I have encountered this issue couple of times this past week. This happened in maya 2024.2 version. I was testing utility node on a cube and a couple of spheres. I don't know if there is a bug or maybe I don't know what I am doing wrong.
 I have posted this screenshot so that it might help someone with the issue.
lee_griggs
Does this happen with new Maya Preferences?
You could try updating to the latest Arnold for Maya plugin:
https://manage.autodesk.com/products/updates
Lee Griggs
Arnold rendering specialist
AUTODESK
bhavinbarbhaya60
So, there was no problem with the prefernces but more like the plug-in itself. I will try to update it with the latest one. The thing is the same thing happend with the xgen as well. So if you switch from xgen to x gen interactive groom the viewport goes blank and there are no options available.
The only thing you could do is restart the application each time you need to change from x gen to interactive goom. I still don't know why this happens. If you like I can send the screenshot just like above as well.
