Advanced Render Log Info
Andrew_Wilkins1
Message 1 of 9
Andrew_Wilkins1
Hi everyone,
I'd really like to find more in-depth technical information on render logs, I was wondering if that info is available anywhere? Really quite interested in the "OpenImageIO Texture statistics" for example.
I've found this doc, but it unfortunately doesn't go into much detail.
https://docs.arnoldrenderer.com/display/ARP/How+to+Read+a+Render+Log
The main goal is to be able to tech check assets / spot unhealthy assets and shots in terms of render optimizations etc.
Edit:
"OpenImageIO ImageCache statistics"
  1. File I/O time -> Are higher/lower times something to look out for?
  2. Redundant Reads vs Cache Memory -> If redundant reads are high, should the cache size be increased for better performance?
  3. Tiles -> I'm guessing the higher values are more of the tiles being seen in shot? Is a higher or lower value something to keep in mind for any reason?
  4. Total pixel data size VS Total actual file size, the pixel data generally being higher than actual file size?
    ---- Other: ----
  5. The warnings "displaced objects have very poor bounds. This can severely affect ray tracing performance." and "Scene creation was a significant amount of total time (57%). Consider optimizing this process first." -> Something to worry about?
  6. The amount of "Shadow" ray counts generally always being one of the highest value, is the a normal occurrence?
    shadow 7205071109 (3474.67, 345.41) ( 80.58%) ( 0.90) ( 9)
  7. What does fairly high "light filter" values/percentage mean, in terms of Shader Calls? Is it that a lot of light decays and gobo's where used? What sort of render impact can those have?
    | light_filter 12533780797 ( 6044.45, 600.86) ( 32.26%)
  8. In terms of .ass file caches I'm assuming that the higher percentage of "reused" caches would mean increased performance and lower ram usage?
    | unique (loaded from disk) 283 (5.93%)
    | reused (found in cache) 4493 (94.07%)
Thanks very much,
Andrew
Replies (8)
Message 2 of 9
Stephen.Blair
No, people usually ask about specific parts of the log, so there's answers posted in different parts of the user community. There's no "advanced render log" documentation tucked away somewhere.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
Andrew_Wilkins1
Okay, thank you Stephen.
Message 4 of 9
Stephen.Blair
@Andrew Wilkins
But please ask and I'll do my best to get some answers...
// Stephen Blair
Message 5 of 9
Andrew_Wilkins1
I've edtited the main post with a couple more specific questions. For when you get a spare moment. 😉
Message 6 of 9
Stephen.Blair
File I/O time
Large I/O times may indicate a network problem eg very slow transfer rates
// Stephen Blair
Message 7 of 9
Stephen.Blair
If redundant reads is large, you'll probably benefit from a larger cache. Redundant reads means tiles are flushed from the cache, and then read back in later.
// Stephen Blair
Message 8 of 9
Stephen.Blair
OIIO (the texture cache) holds uncompressed image data, while files on disk have compressed iamge data
// Stephen Blair
Message 9 of 9
Stephen.Blair
Tiles
If the cache is too small, you'll see more tiles being loaded, because the same tiles are loaded over and over. Check the mip counts:
|   Top files by bytes read:
|     1    265.7 MB ( 2.3%)  8192x8192x4.f32  example.tx MIP-COUNT [1523,1720,671,234,75,17,4,1,1,1,1,1,1,1]
If see huge numbers of reads at the higher mip levels (eg 1523 above for the 8192x8192 mip map level) then the cache is probably too smal
// Stephen Blair
