Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
3DS Max Arnold VDB not showing
reuter.philipp
Message 1 of 11
reuter.philipp
like discribed VDBs are not showing in my Drawing. I just wanted to explore the Scene from:https://docs.arnoldrenderer.com/display/A5AF3DSUG/Rendering+a+Cloud
But if I open the Scene it only shows the Physical Sky but not the Cloud.
I even tryed to create a new Scene but if I open the VDB it asks for Grids, but there are no to select. Img from Tutorial (I have no options there):
My Scene Showcase:
Tryed other VDB Scenes aswell, all with the same result, does somebody know how to solve this?
(Sry for my bad English)
Greetings
Philipp
Replies (10)
Message 2 of 11
lee_griggs
I just tried it now and it worked fine.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 11
lee_griggs
It looks like you haven't downloaded the vdb file link in the tutorial. Download it and open it in the volume.
Lee Griggs
AUTODESK
Message 4 of 11
reuter.philipp
@Lee Griggs Thanks for the Answer 🙂 I have the Files from Disney downloaded and even imported to a new File (I use 3DS 2019). Still nothing visible but like I sayed my Grid Window is completly empty, i think thast why it doesent work, but I cant fix it 😞 (all other VDBs I tested dont have Grids to choose from too)
Message 5 of 11
lee_griggs
Did you try the scene file from the tutorial?
Lee Griggs
AUTODESK
Message 6 of 11
reuter.philipp
Yes, I tried it first with the scene file and it didnt worked, becuse i forgot to downloade the Files from Disney, but even after its still not working. I think it has something to do with the VDB Grids, i couldnt select any Grids no matter wich vdb i tried (even tried the other Tutorials with vdb files, all are not showing)
Message 7 of 11
lee_griggs
I should show the Density grid enabled when it loads the VDB. Just click on OK and it should work.
Lee Griggs
AUTODESK
Message 8 of 11
lee_griggs
You assigned a Standard Volume to it right?
Lee Griggs
AUTODESK
Message 9 of 11
I have exactly the same problem with 3ds max 2019, I can't select any Parameter Grids form any VDB file. Can you Help us?1620818016470.png
Message 10 of 11
reuter.philipp
Hi BÀRBARA MICO-VICENT, I never got it to work with 3Ds Max 2019 unfortunately, I suspect some bug, but if I remember correctly it had worked for me with the 2020+ version.
If you could try if it works and write an answer for all who have the same problem, I would appreciate it.
With kind regards,
Philipp
Message 11 of 11
Stephen.Blair
If the vdb really does have grids, and you know their names, you could type them into the Grids box of the Volume object
// Stephen Blair
// Arnold Renderer Support
