Been trying to locate the OSL node inside Maya but couldn't find it anywhere.
It's documented in the node reference manual here https://support.solidangle.com/display/A5NodeRef/osl
Maya 2018.2, MtoA 2.1.0.3, MacOS 10.13.
Thanks!
Solved by zenop. Go to Solution.
This node is hidden by default - if you go to your mtoa.mtd file, you can see the following:
[node osl] desc STRING "OSL-based shader" maya.name STRING "aiOslShader" maya.id INT 0x00115D56
maya.classification STRING "shader/surface" maya.hide BOOL true
Set maya.hide to false to unhide it. I'm not sure why it's hidden - maybe it's for a good reason.
Thanks so much @Zeno Pelgrims I That did the trick.
On another note, really miss shaders.xyz
