Something wrong with the alpha channel when rendering in Maya 2018
Hi, so I have this scene. There are three separate objects: the stairs, the front wall and the side walls. There is also an AiSkyDomeLight lighting the scene. The Beauty looks okay but when I check the alpha is all wrong. The front wall and the stairs are white, that's correct, but the side walls are in black while the background is white, and should be the other way around. I'm confused. I think there is something to do with the shading but I am not sure, also I'm not sure why the bg is white.
The side walls have a Layered Shader where I have input an aiStandardSurface shader as the base color and a painted texture with transparency from photoshop on top of the base color to add the details you see. Could be this doing something wrong in the Alpha channel?
I've tried changing the Opacity, Opaque and visibility options but not working. Any ideas?
Thanks in advance.
lee_griggs
Can you post your shader network? Are you using a native Maya Layered shader? If so, have you tried Arnolds Layer shader?
Is the skydome color white? The background will be white if the Camera Visibility is 1. Try reducing it to 0.
Lee Griggs
Arnold rendering specialist
AUTODESK
Hi @Lee Griggs thanks for responding, turning the visibility on camera of the skydome worked, thanks!
On the other hand, here's a screenshot of my shading network
As you can see, yes I am using the Maya Layered Shader. If I'm not mistaken, Arnold doesn't have this kind of shader. I know there's an aiMixShader that has similar options, but I already tried it and it didn't worked how I wanted, plus it doesn't have as many settings as the Maya Layered. I know I also could try to input the texture with transparency in the Coat node of the Standard Shader but that would only let me input one node, and I want to have several layers (as you can see in the screenshot). The interesting thing is that everything is working fine in the Beauty pass (well, only one issue and is that somehow when I plug the texture file in the layered shader it changes the color of it, not sure why but I actually don't mind it), it's just in the Alpha that things don't seem to be working, it is strange.
thanks for your time!
lee_griggs
Have you updated your plugin? A new Arnold Layer shader was introduced in 3.0.0 . I'm not sure if Maya's Layered shader is fully supported.
Lee Griggs
AUTODESK
I see! Oh I can't find it in my Maya. My Arnold version is the 2.1.0.1, I guess I will have to update it to the 3.0. Oh well. Thanks for the tip, I will try to solve it! Thanks again @Lee Griggs
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
