Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Rendering of simple scene takes forever with MtoA
2 REPLIES 2
352 Views, 2 Replies
Hi there,
I'm trying to render a simple scene which consists of 1 prop with textures and it takes enormously long whether it's IPR or normal render. To get to the 14% which you see on screenshot took 20 min!
I turned off one of the lights, tried to turn off part of the textures and it didn't help. I didn't change sampling (only on sky dome set to 3) as I wanted to do just quick tests.
What can be wrong here?
System: Intel i7 Coffeelake 3.2Ghz, RAM 32Gb, Geforce RTX 2070
Maya 2018.6
Arnold 3.3.0 (Arnold Core 5.4.0.0)
Tags (2)
Labels (2)
2 REPLIES 2
thiago.ize
You'll want to enable info messages in the arnold log and then at the end of the render Arnold will print out a bunch of stats showing where the time is going. What I usually do for these tests is drop the camera AA down to 1 so that the test renders is just a few minutes -- in your case it should be 9x faster. Post the entire log here and we might be able to identify what could be happening.
One thing I don't get is that you said only 14% was rendered in the screenshot, but in the screenshot it looks like the entire image is rendered?
lee_griggs
Have you also tried using Feature Overrides to try and determine where it is slowing down?
Can you upload a simplified scene that shows the problem (as well as the log)?
Lee Griggs
Arnold rendering specialist
AUTODESK
Technology Administrators
