Renaming custom AOV
Renaming custom AOV
Andrew_Wilkins1
Renaming custom AOV
Andrew_Wilkins1
When renaming AOV's from the render settings UI or attribute editor, it doesn't re-name the main "aiAOV" node—so the naming no longer corresponds. If I were to re-name that as well, it then breaks the "Select AOV node" drop-down button. The naming in the "Active AOV's" also doesn't correspond.
Is this a known problem?
Thank you 🙂
Andrew
Stephen.Blair
Saving and then re-loading the scene should force everything to update.
// Stephen Blair
// Arnold Renderer Support
