Registering MtoA on linux
JosiahErikson2960
Message 1 of 9
JosiahErikson2960
Hi all,
I've just finished a frustrating bout of getting Maya 2018 and MtoA installed on our render farm, which is running CentOS 6.5. I thought I'd post my experience here so that this was documented somewhere on the web, since I couldn't find ANY reference to this anywhere else.
So I was able to get Maya installed and licensed by installing the RPMs and running
export LD_LIBRARY_PATH=/opt/Autodesk/Adlm/R14/lib64/
/usr/autodesk/maya2018/bin/adlmreg -i N 657J1 657J1 2018.0.0.F <serial> /var/opt/Autodesk/Adlm/Maya2018/MayaConfig.pit
as it says in the docs.
I then installed the MtoA plugin, using the docs here:
https://support.solidangle.com/display/AFMUG/Installing+Arnold+for+Maya+on+Linux
Very little about these docs worked. I was unable to find any more recent docs for this process either, even though these are four years old. It is not sufficient to set the environment variables mentioned in those docs. It is also necessary to set
MAYA_PLUG_IN_PATH=/opt/solidangle/mtoa/2018
in Maya.env for Maya to be able to find Arnold.
At this point, I could render with a watermark but licensing was clearly not working, so I turned to these docs, which are much more recent and seem to be up-to-date:
https://support.solidangle.com/display/A5AILIC/%5BCLM%5D+Setting+up+Autodesk+licensing
However, adding the ~/.flexlmrc file pointing to my license server was not sufficient by itself. I discovered, randomly, that I also had to run
/opt/solidangle/mtoa/2018/pit/pitreg
in order to get this to work. Either by itself was not sufficient (I had a lot of render nodes to double-check with), I had to do the ~/.flexlmrc AND the pitreg command. I'm posting here because if you google "/opt/solidangle/mtoa/2018/pit/pitreg" you get literally no results, so I figured this post might help somebody, and perhaps get the docs updated as well.
All the best,
-Josiah Erikson
Replies (8)
Message 2 of 9
Stephen.Blair
You were looking at the old MtoA docs. But that doesn't matter because nothing much has changed.
The install itself is fairly simple, and should take care of everything for you. I rarely have support cases about Linux installs.
It's not necessary to set any environment variables. Everything should work with what's in the MtoA module file.
The installer runs pitreg automatically, so I assume you got some error?
Google pitreg or mtoa pitreg.
The third hit for mtoa pitreg is https://arnoldsupport.com/tag/autodesk-licensing/
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
JosiahErikson2960
I see, that makes sense. I had made an RPM because I need to be able to auto-install on reboot - this is a ROCKS cluster - so that explains it. So now this can be a "steps you need to take if you didn't use the installer but just zipped up the directory and made an RPM out of it so you could more easily install on your render farm" post. Of course now I'll just add that in the post-install section of my RPM... thanks for the clarification. Those docs made it sound like you had to do that, but I see that I was misunderstanding.
Message 4 of 9
Stephen.Blair
It is possible to do a silent install too: https://arnoldsupport.com/2017/10/23/mtoa-running-a-silent-install/
I'll copy that over to the docs soon...
// Stephen Blair
Message 5 of 9
JosiahErikson2960
Oh that's very useful information! Thanks very much for that. Probably now that I've already made the RPM, it's easier to just use that, but it's good to know that's an option.
Message 6 of 9
JosiahErikson2960
Also kudos for the quick responses here. I'm very impressed.
Message 7 of 9
Mario_Positano
Hello!
Unfortunately, I am still getting watermarks after trying the above solution. What is odd is that I am running a small pool (on our farm) twelve machines are rendering fine. Two machine are generating frames with water marks. The machine were all installed and configured the same way and they are all the same hardware. I tried uninstalling and reinstalling Maya and Arnold (MtoA-2.1.0.1-linux-2018.run) but I am still getting water marks on these two nodes. Any hints would be most appreciated.
Here is what I tried:
1. export MAYA_PLUG_IN_PATH=/opt/solidangle/mtoa/2018
2. /opt/solidangle/mtoa/2018/pit/pitreg
3. edit /var/flexlm/maya.lic (to point to the license server)
SERVER 192.168.29.36 0
USE_SERVER
4. /home/SRC/MAYA2018/adlmreg -i N 657J1 657J1 2018.0.0.F [lic number] /var/opt/Autodesk/Adlm/Maya2018/MayaConfig.pit
NOTE: I get this response: Serial Number exists. Skip registration.
5. ~/.flexlm
ADSKFLEX_LICENSE_FILE=/var/flexlm
tried this too:
ADSKFLEX_LICENSE_FILE=/var/flexlm/maya.lic
6. nano ~/maya/2018/Maya.env
Honestly, I thought a re-install would do it but even after all of this, two nodes are getting watermarks.
Any suggestions?
Message 8 of 9
Stephen.Blair
Did you get an error for pitreg during the installation? Then you have to run
If not, then you don't need to run pitreg.
All the other things you did won't help with licensing.
You need to edit ~/.flexlmrc and set ADSKFLEX_LICENSE_FILE:
[email protected]
// Stephen Blair
Message 9 of 9
Mario_Positano
Thank you!
That .flexlmrc worked.
I also had to open up permission on /usr/tmp. Not sure what that wasn't open in the first place.
