Python AOV's shaders
fabriceQ224F
Message 1 of 9
fabriceQ224F
Is there a way to extract shader name from the AOV node with Python? I'd like to get 'cryptomatte' when I know AOV's node name ('crypto_asset' for example). I tried a listAttr on that AOV's node name but couldn't find any one related to the shader name.
Thank you!
Replies (8)
Message 2 of 9
Stephen.Blair
MtoA automatically adds the cryptomatte aov shader when it sees the cryptomatte node (because the cryptomatte node has the aov_shader TRUE metadata in plug-ins\mtoa.mtd)
The shader name is automatically generated.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
fabriceQ224F
Thank you Stephen. But what I'm trying to do is to find the name of the shader connected to an AOV (and, BTW, not especially cryptomattes). So, I have a node's name ('crypto_asset') and I'd like to find the shader called 'cryptomatte' that is connected to it...
Message 4 of 9
Stephen.Blair
For other AOVs, MtoA inserts an aov write node.
So for example, if you create an AOV named "ao" and assign an aiAmbientOcclusion shader to it, then when MtoA translates the scene, MtoA inserts an aov_write_rgba node.
The node is named defaultArnoldRenderOptions/aov_write_rgba_ao
So if you know the type and name of the AOV, you could build the shader name.
// Stephen Blair
Message 5 of 9
fabriceQ224F
Sorry, I made a simple scene with a sphere, an area light and an AO AOV node, but I can't find that aov_write_rgba_ao node... Can we find this in the Outliner? Is it only created during render time and then deleted?
Message 6 of 9
Stephen.Blair
That node never exists in Maya. It exists only in the data that MtoA sends to Arnold.
// Stephen Blair
Message 7 of 9
fabriceQ224F
Ok. Sorry Stephen but I'm a bit lost then, there's no real documentation about Python commands for managing MtoA... How can we concretely ask aov_write_rgba node to give us its shader's name thanks to Python?
Message 8 of 9
Stephen.Blair
You cannot get the name from the Maya scene, or from MtoA. MtoA creates the node and names it when MtoA translates the Maya scene to an Arnold scene. And there's no hooks/callbacks for the translation process that would give you the new node names.
// Stephen Blair
Message 9 of 9
fabriceQ224F
Well... Ok thank you, I'll do it the dirty way then... List source connections to aov's defaultValue attribute, this should give me the shader node's name.
