Orthographic camera not visible in Arnold Render view menu
Parmenides
Parmenides
Often I need to render in Front orthographic view but the camera is not available in Arnold Render view pulldown menu (or Render/camera/) even when it is the active camera. How do I add it?  The only cameras in these menus appear to be perspective and custom cameras.
If I select this front camera in Render Settings I can batch render from that view but it won't show up in Arnold render view.  Really annoying, thanks for any help with this.
Stephen.Blair
If I add front as a renderable camera, then it shows up in the Arnold RenderView
Or I can create a camera, and in the Arnold section, set Camera Type to orthographic
// Stephen Blair
// Arnold Renderer Support
Parmenides
Thanks for the reply. It has been like this for as long as I can remember, even through many times deleting preferences. Any suggestions as to what else I can try to get this to work correctly?
lee_griggs
If you make it Renderable it should appear in the Arnold RenderView camera list. You will need to either Render -> Update Full Scene or close/reopen the window to see it there.
Lee Griggs
Arnold rendering specialist
AUTODESK
