No difference with or without denoising
Message 1 of 9
I'm seeing if I definitely migrate to Arnold & Maya and I was trying to see how good is the Optix Denoiser and I captured two versions: one with denoiser and another without denoiser:
with Optix Denoiser :
without Optix Denoiser :
And the render times are the same.
Hum...What's going on? What am I doing wrong?.
Let's see, maybe it's because of my graphic card, which is a modest Quadro K620 and it renders as fast as my CPU , which is an i7.
Kind regards.
Replies (8)
Message 2 of 9
lee_griggs
What sample settings are you using? Try lowering the Camera (AA) samples. You should notice a difference then.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 9
Reducing the Camera (AA) doesn't mark the difference between two options. Well, let's say of course that the time is reduced by two regarding to a higher number or samples in the camera AA hence:
with denoising:
without denoising:
(We can see that without denoising it takes less time...)
ERfvdsss...Any idea?
Thank you in advance.
Message 4 of 9
lee_griggs
You are not showing the denoise AOV in the Render View. Please read the documentation here.
Lee Griggs
AUTODESK
Message 5 of 9
Let me show you the options checked, are they enough / correct? Do I have to check something else?.
When I render it I see some stage during the progress with a temporal blurry effect which disappears till the final image so the Optix Denoisier is working...But in this way.
Thank you very much for your help.
Best regards.
Message 6 of 9
lee_griggs
That is correct. Test it with another simple scene if you are not sure it is working.
Lee Griggs
AUTODESK
Message 7 of 9
Testing it with another scene (One well known):
with denoiser:
without denoiser:
Again the same times.
What I think is one of two:
a).-Or I'm doing something wrong.
b).-Or my graphic card has not enough CUDA Cores to compete against my i7 microprocessor.
Best regards.
Message 8 of 9
Stephen.Blair
Can we see an Arnold log?
// Stephen Blair
// Arnold Renderer Support
Message 9 of 9
How can I get the log?.
I've been activating some checkboxes in the Render Settings Windows and stablishing some directories but I can't find anything there.
Please if you can help me with it.
Thanks in advance.
