Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
MTOA Portal Light mode
7 REPLIES 7
Message 1 of 8
joie
1575 Views, 7 Replies
Hi there people; I have to render a scene (camera animation) where I have to see the exterior AND the interior of a box truck. So, the doors ar opened and I can see the interior. I thought to use a portal light because the interior goes almost black and super noisy. BUT, if I:
  • Use the portal light in interior mode, the interior is great but the exterior is black
  • Use the portal light in interior_exterior mode, the interior looks great and the exteior too, but ONLY the exterior part in front of the portal light. The exterior part that is BEHIND the portal light is almost black
Is this the intended behaviour?, How I'm supposed to do this scene then?, there are no more portal light modes!. See the problem here:
Thanks for your help in advance.
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
lee_griggs
in reply to: joie
Can you position the Light Portal behind the camera?
How many Diffuse samples are you using? Is the Light Portal reducing the noise substantially?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 8
joie
in reply to: joie
Hi there;
Yes, I can put the portal light behind the camera. I thought it was mandatory to have the portal lights where the openings are, like windows or so. It's great to know that I can put those portal lights ANYWHERE in the scene!. In fact, I could just parent the portal light below the camera, so it is always behind it anytime in the animation, don't you agree?.
The skydome samples are 8 and, yes, the noise is pretty noticeable inside the truck.
Thanks.
Message 4 of 8
lee_griggs
in reply to: joie
Well, it is recommended to have them next to small window openings. To be honest, I am not sure it is needed in this case. If you lower the Skydome samples to 4 (8 is way too excessive) and increase the number of Diffuse samples, doesn't that fix the noise? You can use AOVs to identify where the noise is coming from.
Lee Griggs
AUTODESK
Message 5 of 8
joie
in reply to: joie
Yes, I'm using AOVs to see where to boost the samples. That is critical because, as you may know, the floor of most trucks' boxes are metal plate, so I have to boost diffuse samples but also specular ones. Do you think I should up also that shader samples too?.
thanks for your advises.
Message 6 of 8
lee_griggs
in reply to: joie
Shader samples? What do you mean?
Lee Griggs
AUTODESK
Message 7 of 8
joie
in reply to: joie
I mean the samples on the shader itself, the metal plate shader.
Message 8 of 8
lee_griggs
in reply to: joie
That's not possible.
Lee Griggs
AUTODESK
