mtoa - denoice all lightgroups
- Mute
- Permalink
- Report
How do I denoice RGBA for all lightgroups ?
This is the command:
noice -i //frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb.0000.exr -o //frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr -ef 2 -pr 3 -sr 9 -v 0.25 -l RGBA_Point -l RGBA_Dir -l RGBA_Spot -l RGBA_Area -l RGBA_default -l RGBA_Dome -l RGBA_Pht
This is the output:
Loading file "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb.0000.exr". Using feature AOV 'diffuse_albedo' with filter 'gaussian_filter' Using feature AOV 'N' with filter 'gaussian_filter' Using feature AOV 'Z' with filter 'gaussian_filter' Working with 1 frame at 1920x1080 Will denoise AOV "RGBA", using associated variance Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Area", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Dir", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Dome", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Pht", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Point", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_Spot", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Will just copy AOV "RGBA_default", variance not found Output file will be "//frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr" Start denoising (patch radius 3, search radius 9, variance 0.25) Denoising RGBA Denoising RGBA_Area Could not find AOV with source RGBA_Area and filter variance_filter Could not find variance for AOV "RGBA_Area", skipping denoise. Denoising RGBA_Dir Could not find AOV with source RGBA_Dir and filter variance_filter Could not find variance for AOV "RGBA_Dir", skipping denoise. Denoising RGBA_Dome Could not find AOV with source RGBA_Dome and filter variance_filter Could not find variance for AOV "RGBA_Dome", skipping denoise. Denoising RGBA_Pht Could not find AOV with source RGBA_Pht and filter variance_filter Could not find variance for AOV "RGBA_Pht", skipping denoise. Denoising RGBA_Point Could not find AOV with source RGBA_Point and filter variance_filter Could not find variance for AOV "RGBA_Point", skipping denoise. Denoising RGBA_Spot Could not find AOV with source RGBA_Spot and filter variance_filter Could not find variance for AOV "RGBA_Spot", skipping denoise. Denoising RGBA_default Could not find AOV with source RGBA_default and filter variance_filter Could not find variance for AOV "RGBA_default", skipping denoise. Finished denoising Saving image //frames/defaultRenderLayer/defaultRenderLayer_v5__test_v101.mb_denoised.0000.exr (1920 x 1080 x 32)
As you can see, denoice is expecting variance for each RGBA_lightGroup
and there is only variance channel for beauty RGBA
How do I tell mtoa to export variance for all lightgroups ?
I used:
setAttr "defaultArnoldRenderOptions.outputVarianceAOVs" 1;
For reference, here is rendered AOVs list as reported by exrheader
arnold/aovs/N_noice/filter (type string): "gaussian_filter" arnold/aovs/N_noice/filter_width (type float): 2 arnold/aovs/N_noice/source (type string): "N" arnold/aovs/RGBA/filter (type string): "gaussian_filter" arnold/aovs/RGBA/filter_width (type float): 2 arnold/aovs/RGBA/lpe (type int): 1 arnold/aovs/RGBA/lpe_expression (type string): "C.*" arnold/aovs/RGBA/source (type string): "RGBA" arnold/aovs/RGBA_Area/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Area/filter_width (type float): 2 arnold/aovs/RGBA_Area/lpe (type int): 1 arnold/aovs/RGBA_Area/source (type string): "RGBA_Area" arnold/aovs/RGBA_Dir/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Dir/filter_width (type float): 2 arnold/aovs/RGBA_Dir/lpe (type int): 1 arnold/aovs/RGBA_Dir/source (type string): "RGBA_Dir" arnold/aovs/RGBA_Dome/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Dome/filter_width (type float): 2 arnold/aovs/RGBA_Dome/lpe (type int): 1 arnold/aovs/RGBA_Dome/source (type string): "RGBA_Dome" arnold/aovs/RGBA_Pht/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Pht/filter_width (type float): 2 arnold/aovs/RGBA_Pht/lpe (type int): 1 arnold/aovs/RGBA_Pht/source (type string): "RGBA_Pht" arnold/aovs/RGBA_Point/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Point/filter_width (type float): 2 arnold/aovs/RGBA_Point/lpe (type int): 1 arnold/aovs/RGBA_Point/source (type string): "RGBA_Point" arnold/aovs/RGBA_Spot/filter (type string): "gaussian_filter" arnold/aovs/RGBA_Spot/filter_width (type float): 2 arnold/aovs/RGBA_Spot/lpe (type int): 1 arnold/aovs/RGBA_Spot/source (type string): "RGBA_Spot" arnold/aovs/RGBA_default/filter (type string): "gaussian_filter" arnold/aovs/RGBA_default/filter_width (type float): 2 arnold/aovs/RGBA_default/lpe (type int): 1 arnold/aovs/RGBA_default/source (type string): "RGBA_default" arnold/aovs/Z_noice/filter (type string): "gaussian_filter" arnold/aovs/Z_noice/filter_width (type float): 2 arnold/aovs/Z_noice/source (type string): "Z" arnold/aovs/diffuse_albedo_noice/filter (type string): "gaussian_filter" arnold/aovs/diffuse_albedo_noice/filter_width (type float): 2 arnold/aovs/diffuse_albedo_noice/lpe (type int): 1 arnold/aovs/diffuse_albedo_noice/lpe_expression (type string): "C<RD>A" arnold/aovs/diffuse_albedo_noice/source (type string): "diffuse_albedo" arnold/aovs/variance/filter (type string): "variance_filter" arnold/aovs/variance/filter_width (type float): 2 arnold/aovs/variance/lpe (type int): 1 arnold/aovs/variance/lpe_expression (type string): "C.*" arnold/aovs/variance/source (type string): "RGBA" channels (type chlist): A, 16-bit floating-point, sampling 1 1 B, 16-bit floating-point, sampling 1 1 G, 16-bit floating-point, sampling 1 1 N_noice.X, 16-bit floating-point, sampling 1 1 N_noice.Y, 16-bit floating-point, sampling 1 1 N_noice.Z, 16-bit floating-point, sampling 1 1 R, 16-bit floating-point, sampling 1 1 RGBA_Area.A, 16-bit floating-point, sampling 1 1 RGBA_Area.B, 16-bit floating-point, sampling 1 1 RGBA_Area.G, 16-bit floating-point, sampling 1 1 RGBA_Area.R, 16-bit floating-point, sampling 1 1 RGBA_Dir.A, 16-bit floating-point, sampling 1 1 RGBA_Dir.B, 16-bit floating-point, sampling 1 1 RGBA_Dir.G, 16-bit floating-point, sampling 1 1 RGBA_Dir.R, 16-bit floating-point, sampling 1 1 RGBA_Dome.A, 16-bit floating-point, sampling 1 1 RGBA_Dome.B, 16-bit floating-point, sampling 1 1 RGBA_Dome.G, 16-bit floating-point, sampling 1 1 RGBA_Dome.R, 16-bit floating-point, sampling 1 1 RGBA_Pht.A, 16-bit floating-point, sampling 1 1 RGBA_Pht.B, 16-bit floating-point, sampling 1 1 RGBA_Pht.G, 16-bit floating-point, sampling 1 1 RGBA_Pht.R, 16-bit floating-point, sampling 1 1 RGBA_Point.A, 16-bit floating-point, sampling 1 1 RGBA_Point.B, 16-bit floating-point, sampling 1 1 RGBA_Point.G, 16-bit floating-point, sampling 1 1 RGBA_Point.R, 16-bit floating-point, sampling 1 1 RGBA_Spot.A, 16-bit floating-point, sampling 1 1 RGBA_Spot.B, 16-bit floating-point, sampling 1 1 RGBA_Spot.G, 16-bit floating-point, sampling 1 1 RGBA_Spot.R, 16-bit floating-point, sampling 1 1 RGBA_default.A, 16-bit floating-point, sampling 1 1 RGBA_default.B, 16-bit floating-point, sampling 1 1 RGBA_default.G, 16-bit floating-point, sampling 1 1 RGBA_default.R, 16-bit floating-point, sampling 1 1 Z_noice, 16-bit floating-point, sampling 1 1 diffuse_albedo_noice.B, 16-bit floating-point, sampling 1 1 diffuse_albedo_noice.G, 16-bit floating-point, sampling 1 1 diffuse_albedo_noice.R, 16-bit floating-point, sampling 1 1 variance.A, 16-bit floating-point, sampling 1 1 variance.B, 16-bit floating-point, sampling 1 1 variance.G, 16-bit floating-point, sampling 1 1 variance.R, 16-bit floating-point, sampling 1
