MtoA-3.3.0.1-2018 not render bifrost
elmorsy_pro
Message 1 of 12
elmorsy_pro
the Bifrost liquid don't appear in render
when i use MtoA-3.2.0-2018 every thing show as normal
i use Maya 2018.1
Replies (11)
Message 2 of 12
Stephen.Blair
Please post an Arnold log (verbosity level = Info)
// Stephen Blair
// Arnold Renderer Support
Message 3 of 12
elmorsy_pro
here it is
Message 4 of 12
elmorsy_pro
Message 5 of 12
Stephen.Blair
Ok, now render and get the Arnold log from the Maya output window
// Stephen Blair
Message 6 of 12
elmorsy_pro
Message 7 of 12
Stephen.Blair
I think you don't have Bifrost installed:
00:00:00 ERROR   | [mtoa] [bifrostTranslator] Could not find arnold_bifrost in search path C:/Program Files/Autodesk/Bifrost/Maya2018/
You can get the latest Bifrost from https://area.autodesk.com/bifrost/downloads/
// Stephen Blair
Message 8 of 12
elmorsy_pro
first: how can i don't have Bifrost installed and the liquid displayed in view port
second: i install the last ver of bifrost now the liquid dont displayed in view port and give me error
// Error: Fx_5:bifrostLiquidPropertiesContainer1: transportStepAdaptivity: Could set input port value.
Failed to set input parameter transportStepAdaptivity //
// Error: Bifrost evaluation error //
// Error: Fx_5:bifrostFoamPropertiesContainer1: emissionRate: Could set input port value.
Failed to set input parameter emissionRate //
Message 9 of 12
Stephen.Blair
Please explain this:
// Stephen Blair
Message 10 of 12
I have this variable in Maya.env file
BIFROST_ARNOLD_PATH= C:\Program Files\Autodesk\Arnold\maya2020\extensions\bifrost\1.5.0
Message 11 of 12
elmorsy_pro
now whne i crean new simulation work and render fine
but my old simulation dosn't work at all
any help
Message 12 of 12
Stephen.Blair
Hi @
Could you get another Arnold log ?
This time, use Render > Render Current Frame
Don't use the Arnold Render View (because it does multiple renders at different camera AA levels, and shows only the last one in the log)
thanks
// Stephen Blair
