Hi I have a problem When I load the VDB output from Phoenix FD Maya and enter it into Arnold volume. VDB rendering is rendered as a white box No show Smoke !!! The same VDB file is rendered correctly in 3ds max Volume Arnold !! please help me Thankful
@It's something like this. But it sounds like your shader. So apply an AiStandard volume to the container.
Thank you for answer
But the changes didn't work
I am attaching a vdb file for you to test
It's says smok_phx. Make it capital "S" Smoke_phx and Fuel_phx.
worked
Thank you
did you find a fix? im having the same problem
