Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Maya 2020.4 and MtoA problem
35 REPLIES 35
Message 1 of 36
max_schoenherr
5751 Views, 35 Replies
hi there, i am a maya tutor (uhr24 on youtube) and run the student version of maya 2020.4 on a win 10 machine. since the installation of arnold in it's new version mtoa 4.2.0. several problems have occured, the most obvious one: when i render the scene using the arnold > render option i get a black window and this error message:
Warning: arnold_bifrost.dll was compiled against non-compatible Arnold 6.0.0.0
i can render the scene with the IPR icon right next to the render settings icon. what is this error message about?
Tags (1)
Labels (1)
35 REPLIES 35
Message 2 of 36
in reply to: max_schoenherr
wait for Maya update !
C:\Program Files\Autodesk\Bifrost\Maya2020\2.2.0.1\bifrost\arnold-6.0.0.0
Message 3 of 36
when is the maya update coming out?
Message 4 of 36
no idea! ask Adsk
Message 5 of 36
Bifrost needs an update. Autodesk is working on it.
https://linktr.ee/cg_oglu
Message 6 of 36
Message 7 of 36
Get the latest Bifrost to use with MtoA 4.2
https://area.autodesk.com/bifrost/downloads/
// Stephen Blair
// Arnold Renderer Support
Message 8 of 36
hi stephen, thanks for the info. i updated bif to 2.2.0.2, but the problem remains. i get a black window when i render using Arnold → Render. i can render using the IPR icon next to the render settings icon, but not, as usual, via the Arnold menu.
Message 9 of 36
So you still get this?
WARNING |  arnold_bifrost.dll was compiled against non-compatible Arnold 6.0.0.0
// Stephen Blair
Message 10 of 36
i don't get that specific error message any more, but a black render window. see this (unlisted, temporary) video: https://youtu.be/bUJRRXNJKOE
Message 11 of 36
this is the error message i see: # Warning: [mtoa] Output driver 1 for AOV "RGBA" is null #
Message 12 of 36
The bifrost update wouldn't cause that.
The Output driver warning is because of the Maya Render View.
Can you get a Info-level Arnold log?
// Stephen Blair
Message 13 of 36
Message 14 of 36
Something wrong/corrupt with that PNG file, that's all I can tell.
// Stephen Blair
Message 15 of 36
i have two windows machines, one in my studio, one at home. the one in the studio is still using the previous versions of arnold and bifrost. the one at home is up to date and shows the render problem. i'm reluctant to update the studio machine, and better wait for others having the same problem ... solved.
Message 16 of 36
No problem here with the update, you may add this variable:
BIFROST_ARNOLD_PATH = point to extensions\bifrost\1.5.0
mine look like this:
BIFROST_ARNOLD_PATH= C:\Solidangle\MtoA\maya2020\extensions\bifrost\1.5.0
Hope this help!
Message 17 of 36
Upload a simplified version of the problem scene?
// Stephen Blair
Message 18 of 36
bifArnoldDispute.zipthe scene i showed you is as simple as possible anyway. the problem happens with all scenes.
Message 19 of 36
max_schoenherr
thanks for the hint, but i don't understand it. i guess i have no solidangle folder on my machine.
Message 20 of 36
because I installed MtoA in c:\Solidangle\Mtoa.
You have to point to C:\Program Files\Autodesk\maya2020\Arnold\extensions\bifrost\1.5.0
