Matte AOVs through Glass Not Appear
In this character its build in one mesh with rigging and deformations, have multiples shaders apply with selection components, when i made the Mette AOV in Custom AOV window and do the render, does not appear in the render thought the glass, i was try to do the AOV in render setup window but i can make the material override for shader signed in the part of the mesh, could help me with this, thank you and have a great day
in photoshop i was made manually the rest of the mask, but in a render sequence its not a solution.
here the result
  • aovs
edenexposito
Hola Juan, me acabo de tropezar con el mismo problema. ¿encontraste alguna solucion?
Hola Eden, lamentablemente no encuentro solución y ese problema lo tengo hace un buen tiempo atrás, la única solución es hacer mascaras con rotoscopia en post pero es mucho laburo.
lee_griggs
Transmit AOVs are now available in the latest release.
Lee Griggs
Arnold rendering specialist
AUTODESK
Its awesome, finally its available and working, thank you for the tip
mmlodzienski
@Lee Griggs hey, I have a follow up to this question. I've enabled transmit AOVs, but it doesn't work for Z depth. Specifically, I have POV shots from inside a vehicle and I'd like to be able to output a working Z pass for compositing. Right now it's fairly useless, as it just renders the depth of the window. Is there a way to add the Z depth to the transmitted AOVs? Or more broadly, a way to exclude those windows from the depth calculations? Or would the solution be to render the DOF in engine?
