Light Linking with Mesh Light
kitaguchi-kazuya
kitaguchi-kazuya
Does Mesh Light support light linking?
Though I tested it on MtoA5.4 and 5.5,it doesn't seem to support.
lee_griggs
It is working here. Did you create the mesh_light via the Arnold Menu?
Lee Griggs
Arnold rendering specialist
AUTODESK
kitaguchi-kazuya
I noticed that Mesh Light works if the defaultLightSet has lights in it.
This is the regular environment.
But my environment was irregualr.
In my environment,all lights are intentionally excluded from defaultLightSet by default.
Directional Lights work while Mesh Lights don't work for light linking.
Mesh Lights defined by a "sphere" shape always illuminate a secene even if I exclude them from lignt linking.
Mesh Lights defined by a "plane" shape never illuminate a scene.
I think these behaviors were incorect.
I attach my scene.
MrEddie
@lee_griggs
Just to come back to this. I think that meshlights, illuminate by default, ie when I disconnect it from the default light set, it still illuminates.  You can see below the skydome has no effect when disconnected.
So normal excluding objects in the relationship editor will work, but custom light linking that other lights obey doesn't seem to be the case with aiMeshLight. Probably known about as the illuminate by default checkbox is missing. Something to be fixed ?
I am on an older version so apologies if this is already adressed.
MtoA 5.3.4.1 - 4d32feb2 (fix-5.3.4) - Oct 17 2023 10:57:46
Alan.
lee_griggs
Light centric light linking works for me here.
Lee Griggs
AUTODESK
MrEddie
Thanks Lee,
Can I confirm that aiMeshLights can't be disconnected from the defaultLightSet (or that they don't respect being disconnected) ?
Alan.
