Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
is there a way to map the specular normal on the Standard Surface?
3 REPLIES 3
408 Views, 3 Replies
is there a way to map the specular normal on the Standard Surface? I remember using this quite a bit on the alSurface but it appears that on the standard surface, only the sheen and coat normal are exposed. Would I rather just rely on the coat? how does the coat differ from the specular?
Labels (4)
3 REPLIES 3
lee_griggs
Have you tried Coat Normal?
Lee Griggs
Arnold rendering specialist
AUTODESK
in reply to: lee_griggs
thanks, I was thinking of doing this. does the Coat differ from the specular or is it just a 2nd specular?
lee_griggs
Yes, a second clear coat specular.
Lee Griggs
AUTODESK
Technology Administrators
