Is the command line region render flag broken?
giandosopaolo
Message 1 of 8
giandosopaolo
I am trying to render only the bottom region of my maya animated sequence by using the command line render.
In the command editor I wrote:
>render -r arnold -s 126 -e 242 -reg 0 1919 900 1079 -im MyScene_01 E:\_Projects\MyScene\MyScene.mb
The render starts as usual, but I noticed that Arnold is rendering the full 1920x1080 image, not just the region I selected and the render time is not diminishing.
Am I doing something wrong?
Should it be -reg 0 1919 900 1079 or -reg 0 1920 900 1080 ?
Is anything broken?
@thiago.ize
Replies (7)
Message 2 of 8
LFGFX3D
Yes, it seems the -reg flag has been broken for a while now. There is a workaround though - use the following command in the Ai User Option of the defaultArnoldRenderOptions:
region_min_x # region_max_x # region_min_y # region_max_y #
where #s are your pixel coordinates
Message 3 of 8
Stephen.Blair
That was supposed to be fixed in MtoA 5.1.1.1
  • MTOA-999 - Region Min and Region Max values are not exported
// Stephen Blair
// Arnold Renderer Support
Message 4 of 8
Stephen.Blair
Looks like that fix never made it in, or we broke it again. I've reopened the ticket.
Here's how to set the user options on the render command line:
render -r arnold -s 1 -e 1 -ai:lve 3 -preRender "setAttr -type \"string\" defaultArnoldRenderOptions.aiUserOptions \"region_min_x 0 region_max_x 1919 region_min_y 900 region_max_y 1070\";" example.ma
// Stephen Blair
Message 5 of 8
giandosopaolo
Thanks! 😊
Message 6 of 8
giandosopaolo
I tried using the line of text you suggested in the command line @Stephen.Blair
It seems like Arnold gets stuck when I use it. Meaning it keeps precalculating the shot but never really starts rendering it. 😕
Message 7 of 8
giandosopaolo
Ok, it seems that it works, but only if I add xres 1920 yres 1080 before region_min_x
Message 8 of 8
Stephen.Blair
Works fine for me when I try it.
xres and yres should always be exported. I don't know how to make them not be exported...maybe it's something in the scene setup?
// Stephen Blair
