Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
I want to create some laser beam light effect with maya arnold, how its possible?
3 REPLIES 3
2412 Views, 3 Replies
3 REPLIES 3
Christoph_Schaedl
Like in real live you need smoke/fog to make a laser visible. Play with VDB fog that could work.
https://linktr.ee/cg_oglu
aaronfross
You can also use a Mesh Light, that might be easier to set up and render than volumetric effects. You won't get glow around the Mesh Light, but you could render it out as a separate AOV and add glow in post.
lee_griggs
A laser beam effect can be achieved by using a high 'lens radius' and a low cone angle (atmosphere volume enabled). Here is an example:
Lee Griggs
Arnold rendering specialist
AUTODESK
