Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to render the highlights seen from inside the cockpit
5 REPLIES 5
384 Views, 5 Replies
I simply made a scene, you can see what I want from my reference picture001.jpg002.jpgsnipaste-2021-12-28-21-44-09.jpgsnipaste-2021-12-28-21-44-34.jpg
Tags (2)
Labels (2)
5 REPLIES 5
in reply to: 937884283
They don’t seem to see the highlights. What solutions do you use to solve them?Thanks.
lee_griggs
Add a dirt/smudge/scratch map to specular_roughness and maybe a slight bump map too.
Lee Griggs
Arnold rendering specialist
AUTODESK
in reply to: lee_griggs
I am very glad to see your answer. Please look at the picture below. The inherent colors and highlights are very obvious in the direct sun. The rendering outside the glass is correct, but the rendering effect inside the cockpit is not correct.Thanks. 003.png05.png
Thank you very much for your reply. I have added a light below. This should be his correct performance. The highlights and inherent colors are obvious under direct light.007.png009.jpgImage Caption
lee_griggs
Have you tried this scratches osl shader?
https://arnold-rendering.com/2020/03/20/scratches-osl-shader/
Lee Griggs
AUTODESK
Technology Administrators
