Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How can i use textures for opacity with the ambient occlusion shader in MtoA 2.0.1 for Maya 2017?
6 REPLIES 6
3844 Views, 6 Replies
Tags (2)
Labels (2)
6 REPLIES 6
Stephen.Blair
As of Arnold 5, the opacity, ambient occlusion, and flat shaders are color shaders. They don't support opacity. You'll have to combine one of those shaders with a shader that does handle opacity (for example, use the color from ambient occlusion with the opacity from standard surface).
// Stephen Blair
// Arnold Renderer Support
Thank you so much@Stephen Blair
Mr.baiking
I connect ambient occlusion to standard surface with opactiy, the beauty pass is fine , but i want to write this to the AOVs, it return black
Oh god..thanks a lot for this. I almost went crazy searching for the opacity option, and i coulndt find it since it was removed.
Guilherme_Trevisan
I once needed an AO + Opacity for the leaves of a tree. To make it work I created an AiStandardSurface and plugged an AiAmbientOcclusion(OutColor) to its Emission Color (Emission Weight = 1), and removed any Base color and Specular.
After that I plugged the alpha of my leaf image to opacity R,G and B.
Then in visibility for the object I turned off everything except Primary Visibility,Cast Shadows, and Self Shadows. This worked for me.
parabhdeep
For Alpha Ambient Occlusion
  • Go to render setting -> AOVS Tab->Add Custom
  • Add custom AOV and name it Occlusion
  • Select AOV and go to custom AOV Shader-> Add aiUtility shader to it
  • select aiUtility and shade mode to ambocc
Technology Administrators
