I keep getting this warning when I load older scenes:
In some scenes, it's enough to turn off Display > DAG Objects Only in the outliner and then delete the mental* nodes, but that doesn't work in every scene.
This MEL script is what I've been using, don't remember the origination, but it works!
The MEL script to remove MentalRay residual nodes...
print("\n"); print("\n"); print("Working on:\n"); string $mrNodes[] = `ls -typ "unknown"`; for ($each in $mrNodes){ if (`objExists $each` && `unknownNode -q -p $each` == "Mayatomr"){ print($each + "\n"); delete $each; } } if (`objExists mentalrayIblShape1`){ delete mentalrayIblShape1; } unknownPlugin -remove "Mayatomr"; print "\n"; print "---> Done";
