GPU: Isolate Selected not working
thales_simonato
thales_simonato
Hello all,
I hope you are doing well.
Simple question: Does the Isolate selected works when rendering with GPU? If so, should I do something before to make it work? Am I missing something?
Window 11, Maya 2023.3.1, Arnold 5.4.8.2
Thank you so much
darioOrtisi
It doesn't work even on my side MtoA 5.5.2.1
MrEddie
Bump!
I just spent 8 hours editing a .ma file thinking I had a scene or setup issue until I discovered it was because GPU rendering was enabled and my isolation was not working. What is the status with this? Known limitation?
I have searched all the release notes and nothing is mentioned?
Alan.
MrEddie
Ok - I received a reply from Stephen Blair @ Autodesk, this is a known limitation and there is a ticket for it so they are looking at it. (2026).
