01:33:41 6358MB | 30% done -- estimated remaining time = 12228.1s
01:49:04 6472MB | 35% done -- estimated remaining time = 12183.7s
02:05:19 6516MB | 40% done -- estimated remaining time = 12065.3s
02:21:33 7564MB | 45% done -- estimated remaining time = 10094.6s
02:37:39 7346MB | 50% done -- estimated remaining time = 10072.6s
02:55:20 9912MB | 55% done -- estimated remaining time = 10376.9s
03:38:10 7272MB | 60% done -- estimated remaining time = 16427.4s
04:05:44 7425MB | 65% done -- estimated remaining time = 1101.4s
04:05:44 7425MB | 100% done -- estimated remaining time = 0.0s
04:05:44 7752MB | render done in 4:01:26.791
04:05:54 8750MB | [driver_exr] writing file `D:/_Projects/Mydas/Maya/images/Faces/Mydas_Face_Mydas_003b_iRender_0011.exr'
04:05:54 8767MB | render done
04:05:54 8769MB |
04:05:54 8769MB | -----------------------------------------------------------------------------------
04:05:54 8769MB | scene creation time 1:27.80 machine utilization (2.69%)
04:05:54 8769MB | unaccounted 1:27.80
04:05:54 8769MB | frame time 4:04:26.82 machine utilization (17.84%)
04:05:54 8769MB | node init 0:01.27
04:05:54 8769MB | sanity checks 0:00.27
04:05:54 8769MB | ass parsing (procs) 0:00.08
04:05:54 8769MB | driver init/close 0:10.61
04:05:54 8769MB | subdivision 0:22.97
04:05:54 8769MB | threads blocked 0:00.09
04:05:54 8769MB | mesh processing 0:34.54
04:05:54 8769MB | displacement 1:18.05
04:05:54 8769MB | threads blocked 0:37.45
04:05:54 8769MB | gpu prepare 2:32.58
04:05:54 8769MB | gpu update 0:13.27
04:05:54 8769MB | gpu jit compile / BVH 0:35.74
04:05:54 8769MB | rendering 4:00:51.04
04:05:54 8769MB | output driver 0:00.02
04:05:54 8769MB | pixel rendering 4:00:51.01 (423 sample iterations @ min: 0:00.065, avg: 0:34.163, max: 2:41.595)
04:05:54 8769MB | unaccounted -2:13.28
04:05:54 8769MB | top session self-times by category
04:05:54 8769MB | top session self-times by node
04:05:54 8769MB | peak CPU memory used 37461.75MB
04:05:54 8769MB | at startup 1075.66MB
04:05:54 8769MB | AOV samples 147.15MB
04:05:54 8769MB | output buffers 7.00MB
04:05:54 8769MB | framebuffers 221.00MB
04:05:54 8769MB | node overhead 0.64MB
04:05:54 8769MB | message passing 0.02MB
04:05:54 8769MB | memory pools 14.05MB
04:05:54 8769MB | geometry 11911.09MB
04:05:54 8769MB | polymesh 55.63MB
04:05:54 8769MB | subdivs 11412.53MB
04:05:54 8769MB | curves 442.93MB
04:05:54 8769MB | quad importance map 0.13MB
04:05:54 8769MB | strings 24.25MB
04:05:54 8769MB | texture cache 4096.00MB
04:05:54 8769MB | unaccounted 19964.76MB
04:05:54 8769MB | peak GPU memory consumed 22705.65MB
04:05:54 8769MB | output buffers 127.41MB
04:05:54 8769MB | geometry 16035.40MB
04:05:54 8769MB | polymesh 88.08MB
04:05:54 8769MB | subdivs 15452.50MB
04:05:54 8769MB | curves 494.82MB
04:05:54 8769MB | texture cache 2148.11MB
04:05:54 8769MB | unaccounted 4394.74MB
04:05:54 8769MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
04:05:54 8769MB | camera 328612273 ( 0.93, 1.00) ( 1.54%) ( 0.98) ( 1)
04:05:54 8769MB | shadow xxx-xxxxxxxx ( 49.67, 53.13) ( 81.60%) ( 0.67) ( 1)
04:05:54 8769MB | diffuse_reflect 150928600 ( 0.43, 0.46) ( 0.71%) ( 0.98) ( 1)
04:05:54 8769MB | diffuse_transmit 63018 ( 0.00, 0.00) ( 0.00%) ( 0.97) ( 1)
04:05:54 8769MB | specular_reflect 445677590 ( 1.27, 1.36) ( 2.08%) ( 0.99) ( 1)
04:05:54 8769MB | bssrdf 3012767649 ( 8.57, 9.17) ( 14.08%) ( 0.05) ( 1)
04:05:54 8769MB | total xxx-xxxxxxxx ( 60.87, 65.11) (100.00%) ( 0.60) ( 1)
04:05:54 8769MB | by ray depth: 0 1 2 3 4 5 6 7
04:05:54 8769MB | total 56.1% 24.1% 11.7% 6.3% 1.4% 0.3% 0.0% 0.0%
04:05:54 8769MB | meshes 94
04:05:54 8769MB | shader calls 172642420
04:05:54 8769MB | geometry (% hit ) (instances) ( init mem, final mem)
04:05:54 8769MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
04:05:54 8769MB | procs 12 (100.0%) ( 0) ( 0.00, 0.00)
04:05:54 8769MB | polymeshes 21 (100.0%) ( 0) ( 55.67, 55.63)
04:05:54 8769MB | subdivs 106 (100.0%) ( 0) ( 562.14, 11412.53)
04:05:54 8769MB | curves 12 (100.0%) ( 0) ( 442.93, 442.93)
04:05:54 8769MB | curves 9 had pixel-width optimization
04:05:54 8769MB | geometric elements ( min) ( avg.) ( max)
04:05:54 8769MB | objects (procs) 12 ( 1) ( 1.0) ( 1)
04:05:54 8769MB | polygons 1444125 ( 😎 ( 68767.9) ( 598005)
04:05:54 8769MB | subdiv patches 17810774 ( 60) ( 168026.2) ( 1209576)
04:05:54 8769MB | curves 551196 ( 614) ( 45933.0) ( 177096)
04:05:54 8769MB | curve segments 10402866 ( 1842) ( 866905.5) ( 6302439)
04:05:54 8769MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
04:05:54 8769MB | polymeshes 2882572 ( 16) ( 137265.3) ( 1191390) ( 2.00) ( 0.81%)
04:05:54 8769MB | subdivs 353441793 ( 200) ( 3334356.5) (102799176) ( 19.84) ( 99.19%)
04:05:54 8769MB | adaptive 353441793 ( 200) ( 3334356.5) (102799176) ( 19.84) ( 99.19%)
04:05:54 8769MB | unique triangles 356324365
04:05:54 8769MB | CPU memory use 11468.16MB
04:05:54 8769MB | vertices 2355.49MB
04:05:54 8769MB | vertex indices 2133.78MB
04:05:54 8769MB | polygon base offsets 0.00MB
04:05:54 8769MB | polygon IDs 0.00MB
04:05:54 8769MB | triangulation 0.00MB
04:05:54 8769MB | packed normals 783.80MB
04:05:54 8769MB | normal indices 10.58MB
04:05:54 8769MB | uv coords 714.10MB
04:05:54 8769MB | uv coords idxs 2122.44MB
04:05:54 8769MB | P reference (autobump) 2206.01MB
04:05:54 8769MB | N reference (autobump) 735.34MB
04:05:54 8769MB | uniform indices 401.22MB
04:05:54 8769MB | userdata 0.96MB
04:05:54 8769MB | GPU memory use 15540.58MB
04:05:54 8769MB | vertex indices 6211.58MB
04:05:54 8769MB | normals 783.80MB
04:05:54 8769MB | uv coords idxs 2122.43MB
04:05:54 8769MB | other 0.02MB
04:05:54 8769MB | largest polymeshes by triangle count
04:05:54 8769MB | 102799176 tris -- /Layout/Mydas_posed_UVd/Mydas_Hymation_exported_UVd/Mydas_Hymation_exported_UVdShape
04:05:54 8769MB | 69753054 tris -- /Layout/Mydas_posed_UVd/Mydas_Chyton_extruded_UVd/Mydas_Chyton_extruded_UVdShape
04:05:54 8769MB | 36067486 tris -- /Layout/Dora_GRP/Peplos_extruded_UVd_02/Peplos_extruded_UVd_02Shape
04:05:54 8769MB | 31119134 tris -- /Layout/Room_GRP/Floor_Sides/Floor_SidesShape
04:05:54 8769MB | 21803384 tris -- /Layout/Floor_Center/Floor_CenterShape
04:05:54 8769MB | ass file cache
04:05:54 8769MB | unique (loaded from disk) 12 (100.00%)
04:05:54 8769MB | reused (found in cache) 0 (0.00%)
04:05:54 8769MB | total referenced .ass files 12 (100.00%)
04:05:54 8770MB | OpenImageIO Texture statistics
04:05:54 8770MB | Options: gray_to_rgb=true flip_t=false max_tile_channels=6
04:05:54 8770MB | Queries/batches :
04:05:54 8770MB | texture : 172642461 queries in 172642461 batches
04:05:54 8770MB | texture 3d : 0 queries in 0 batches
04:05:54 8770MB | shadow : 0 queries in 0 batches
04:05:54 8770MB | environment : 0 queries in 0 batches
04:05:54 8770MB | gettextureinfo : 0 queries
04:05:54 8770MB | Interpolations :
04:05:54 8770MB | closest : 41
04:05:54 8770MB | bilinear : 136293864
04:05:54 8770MB | bicubic : 187809942
04:05:54 8770MB | Average anisotropic probes : 1.34
04:05:54 8770MB | Max anisotropy in the wild : 3.78e+05
04:05:54 8770MB |
04:05:54 8770MB | OpenImageIO ImageCache statistics (0000019B7BA3C040) ver 2.4.1.1dev
04:05:54 8770MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
04:05:54 8770MB | autoscanline=true automip=false forcefloat=false
04:05:54 8770MB | accept_untiled=true accept_unmipped=true deduplicate=true
04:05:54 8770MB | unassociatedalpha=false failure_retries=0 openexr:core=0
04:05:54 8770MB | Images : 206 unique
04:05:54 8770MB | ImageInputs : 206 created, 204 current, 204 peak
04:05:54 8770MB | Total pixel data size of all images referenced : 22.7 GB
04:05:54 8770MB | Total actual file size of all images referenced : 10.0 GB
04:05:54 8770MB | Pixel data read : 4.4 GB
04:05:54 8770MB | File I/O time : 28m 37.7s (1m 41.0s average per thread, for 17 threads)
04:05:54 8770MB | File open time only : 3.3s
04:05:54 8770MB | ImageInput mutex locking time : 0.4s
04:05:54 8770MB | Tiles: 267617 created, 239613 current, 239709 peak
04:05:54 8770MB | total tile requests : 435146698
04:05:54 8770MB | micro-cache misses : 1487426 (0.3%)
04:05:54 8770MB | main cache misses : 267617 (0.1%)
04:05:54 8770MB | redundant reads: 20 tiles, 440 KB
04:05:54 8770MB | Peak cache memory : 4.0 GB
04:05:54 8770MB | Image file statistics:
04:05:54 8770MB | opens tiles MB read --redundant-- I/O time res File
04:05:54 8770MB | 1 1 158 3.7 0.1s 1024x1024x3.f16 C:/Users/paolog/Desktop/Mydas/Maya/sourceimages/MydasScalpShape_Mydas_Grooming_01_Mydas_Hair_01_color.tx MIP-UNUSED MIP-COUNT[158,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 2 1 136 1.1 0.0s 1024x1024x1.f16 C:/Users/paolog/Desktop/Mydas/Maya/sourceimages/Mydas_scalp_beardShape_Mydas_Grooming_01_Mydas_Beard_01_Color_mask.tx MIP-UNUSED MIP-COUNT[136,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 3 1 32 0.2 0.0s 1024x1024x1.f16 D:/_Projects/Mydas/Maya/sourceimages/Mydas_scalp_eyebrowsShape_Mydas_Grooming_01_Mydas_Eyebrows_01_MydasHairbrows_01_Color_mask.tx MIP-UNUSED MIP-COUNT[32,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 4 1 2320 36.2 0.7s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Apples_01_DSP_8k_32bit.tx MIP-COUNT[885,687,482,195,56,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 5 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Apples_Gold_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:54 8770MB | 6 1 11 0.0 0.3s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Apples_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 7 1 9904 154.8 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_01_DSP_8k_32bit.tx MIP-COUNT[6722,2300,638,177,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 8 1 9869 154.2 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_02_DSP_8k_32bit.tx MIP-COUNT[6683,2304,637,178,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 9 1 10310 161.1 2.7s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_03_DSP_8k_32bit.tx MIP-COUNT[7169,2260,636,178,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 10 1 10470 163.6 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Bread_01_DSP_8k_32bit.tx MIP-COUNT[7219,2302,680,196,57,15,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 11 1 10635 166.2 2.6s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Bread_02_DSP_8k_32bit.tx MIP-COUNT[7391,2292,683,196,57,15,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 12 1 4858 75.9 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_01_DSP_8k_32bit.tx MIP-COUNT[2464,1483,651,187,52,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 13 1 1749 27.3 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_02_DSP_8k_32bit.tx MIP-COUNT[531,553,474,136,40,11,3,0,0,0,0,0,0,1]
04:05:54 8770MB | 14 1 2087 32.6 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_03_DSP_8k_32bit.tx MIP-COUNT[993,560,348,133,38,12,2,0,0,0,0,0,0,1]
04:05:54 8770MB | 15 1 4844 75.7 2.2s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_04_DSP_8k_32bit.tx MIP-COUNT[2462,1472,651,186,52,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 16 1 4681 73.1 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_05_DSP_8k_32bit.tx MIP-COUNT[2242,1449,710,203,56,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 17 1 420 6.6 0.1s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Butter_DSP_8k_32bit.tx MIP-COUNT[96,136,124,45,14,4,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 18 1 425 10.0 10.1s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_ALB.tx MIP-COUNT[220,102,52,26,14,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 19 1 535 6.3 10.5s 8192x8192x3.u8 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_NRM.tx MIP-COUNT[0,264,132,72,40,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 20 1 27 0.1 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_RGH.tx MIP-COUNT[0,0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 21 1 2622 41.0 0.4s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Cup_01_DSP_8k_32bit.tx MIP-COUNT[771,793,773,226,58,0,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 22 1 27 0.3 0.7s 4096x4096x3.u8 D:/_Projects/Mydas/Textures/Cup_01_MSK_8k_8bit.tx MIP-COUNT[0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 23 1 2138 16.7 0.4s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Cup_02_Gold_Height.1001.tx MIP-COUNT[1169,742,197,30,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 24 1 989 23.2 32.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Cup_02_Gold_Normal.1001.tx MIP-COUNT[544,236,128,54,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 25 1 1563 6.1 4.6s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Cup_02_Gold_Roughness.1001.tx MIP-COUNT[800,448,224,64,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 26 1 8484 132.6 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Cup_03_DSP_8k_32bit.tx MIP-COUNT[5185,2153,846,235,50,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 27 1 81 1.9 1.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_ALB.tx MIP-COUNT[0,18,22,20,10,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 28 1 111 1.3 1.7s 8192x8192x3.u8 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_NRM.tx MIP-COUNT[0,0,28,32,28,12,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 29 1 11 0.0 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_RGH.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 30 1 1456 11.4 0.2s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Cup_04_Height.1001.tx MIP-COUNT[571,604,217,48,16,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 31 1 7 0.2 0.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Cup_04_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:54 8770MB | 32 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Cup_04_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 33 1 91 2.1 2.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Curtains_4K_Albedo.tx MIP-COUNT[0,0,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 34 1 91 1.1 0.4s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/Curtains_4K_Normal.tx MIP-COUNT[0,0,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 35 1 1024 16.0 0.1s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u0_v0.tx MIP-COUNT[289,433,223,62,16,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 36 1 2885 45.1 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2088,614,161,17,4,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 37 1 2891 45.2 0.5s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u2_v0.tx MIP-COUNT[1916,733,215,23,3,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 38 1 2267 35.4 0.4s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u3_v0.tx MIP-COUNT[1194,785,222,60,5,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 39 1 1378 21.5 0.2s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[568,499,228,62,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 40 1 791 18.5 35.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1001.tx MIP-COUNT[450,204,82,28,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 41 1 373 8.7 10.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1002.tx MIP-COUNT[198,84,40,28,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 42 1 113 2.6 4.6s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1003.tx MIP-COUNT[40,30,14,8,10,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 43 1 103 2.4 3.3s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1004.tx MIP-COUNT[32,18,14,16,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 44 1 7 0.2 0.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1005.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 45 1 1179 4.6 6.7s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1001.tx MIP-COUNT[704,304,112,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 46 1 699 2.7 2.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1002.tx MIP-COUNT[320,208,80,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 47 1 379 1.5 1.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1003.tx MIP-COUNT[160,96,64,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 48 1 251 1.0 1.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1004.tx MIP-COUNT[64,64,48,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 49 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1005.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 50 1 2230 17.4 ( 1 0.0) 1.1s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Height.1001.tx MIP-COUNT[1984,213,17,8,8,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 51 1 421 9.9 17.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Normal.1001.tx MIP-COUNT[184,110,68,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 52 1 699 5.5 8.4s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Roughness.1001.tx MIP-COUNT[328,184,112,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 53 1 662 15.5 1.5s 1600x1200x3.f16 D:/_Projects/Mydas/Textures/Fabric_normalMap_02_details.tx MIP-COUNT[475,130,35,12,4,1,1,1,1,1,1]
04:05:55 8770MB | 54 1 640 15.0 14.2s 1399x1399x3.f16 D:/_Projects/Mydas/Textures/Fabric_normalMap_details.tx MIP-COUNT[464,121,36,9,4,1,1,1,1,1,1]
04:05:55 8770MB | 55 1 1171 9.1 0.1s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Figs_8k_DSP.tx MIP-COUNT[378,287,265,166,54,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 56 1 11 0.0 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Figs_Gold_Metalness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 57 1 11 0.0 0.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Figs_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 58 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Figs_NRM_DirectX.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 59 1 2437 76.2 1m 52.1s 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Base_Color.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 60 1 9507 74.3 3.0s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Height.tx MIP-COUNT[4831,3875,777,24,0,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 61 1 2437 76.2 58.4s 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Normal_DirectX.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 62 1 435 3.4 3.6s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Roughness.tx MIP-COUNT[0,64,112,168,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 63 1 5467 170.8 3m 34.9s 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 64 1 4712 36.8 3.7s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Height.tx MIP-COUNT[3376,1024,256,56,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 65 1 5467 170.8 27.4s 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Normal_DirectX.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 66 1 539 4.2 4.6s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Roughness.tx MIP-COUNT[24,176,248,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 67 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Fruit_LP_forSubstance_B_Ribes_SG_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 68 1 4292 67.1 0.9s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Jewels_DSP_8k_32bit.tx MIP-COUNT[2068,1238,674,236,64,9,2,0,0,0,0,0,0,1]
04:05:55 8770MB | 69 1 1650 25.8 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Knife_DSP_8k_32bit.tx MIP-COUNT[639,568,316,100,26,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 70 1 379 3.0 0.9s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Knife_Gold_Roughness_01.tx MIP-COUNT[24,184,112,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 71 1 4579 71.5 0.9s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/L_Shoe_DSP_8k_32bit.tx MIP-COUNT[3343,929,250,55,1,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 72 1 1635 25.5 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Lemons_01_DSP_8k_32bit.tx MIP-COUNT[564,435,325,228,62,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 73 1 11 0.1 0.2s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Lemons_Gold_Metalness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 74 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Lemons_Gold_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 75 1 11 0.1 0.0s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Lemons_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 76 1 1883 29.4 ( 1 0.0) 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u0_v0.tx MIP-COUNT[890,677,227,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 77 1 2899 45.3 ( 1 0.0) 0.7s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2093,626,161,18,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 78 1 2706 42.3 0.5s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u2_v0.tx MIP-COUNT[1835,667,181,22,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 79 1 2718 42.5 0.4s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u3_v0.tx MIP-COUNT[1747,739,208,23,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 80 1 629 9.8 ( 1 0.0) 0.3s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[322,211,67,22,6,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 81 1 15 0.4 0.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_L_Shoe_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,4,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 82 1 27 0.1 0.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_L_Shoe_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 83 1 7 0.2 0.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_R_Shoe_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 84 1 11 0.0 0.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_R_Shoe_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 85 1 7 0.2 0.5s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_Shoes_Oraments_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 86 1 11 0.1 0.1s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Mydas_Shoes_Oraments_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 87 1 2833 66.4 1m 25.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1001.tx MIP-COUNT[1872,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 88 1 475 11.1 15.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1002.tx MIP-COUNT[280,90,54,26,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 89 1 13 0.3 0.7s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1003.tx MIP-COUNT[0,0,0,2,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 90 1 633 14.8 18.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1004.tx MIP-COUNT[368,142,60,36,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 91 1 2317 54.3 1m 30.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1005.tx MIP-COUNT[1324,658,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 92 1 1259 4.9 0.2s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Coat.1001.tx MIP-COUNT[912,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 93 1 2835 66.4 2m 12.3s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1001.tx MIP-COUNT[1874,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 94 1 475 11.1 18.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1002.tx MIP-COUNT[280,90,54,26,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 95 1 13 0.3 0.9s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1003.tx MIP-COUNT[0,0,0,2,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 96 1 633 14.8 24.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1004.tx MIP-COUNT[368,142,60,36,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 97 1 969 22.7 26.5s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1005.tx MIP-COUNT[636,208,74,28,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 98 1 1675 6.5 3.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1001.tx MIP-COUNT[976,448,160,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 99 1 235 0.9 0.6s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1002.tx MIP-COUNT[96,48,32,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 100 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1003.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 101 1 523 2.0 1.5s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1004.tx MIP-COUNT[192,144,96,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 102 1 1051 4.1 0.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1005.tx MIP-COUNT[288,416,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 103 1 3835 15.0 6.9s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1001.tx MIP-COUNT[2576,912,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 104 1 955 3.7 1.7s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1002.tx MIP-COUNT[544,256,80,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 105 1 43 0.2 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1003.tx MIP-COUNT[0,0,0,16,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 106 1 1099 4.3 3.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1004.tx MIP-COUNT[608,272,128,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 107 1 1403 5.5 0.5s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1005.tx MIP-COUNT[896,320,128,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 108 1 16107 125.8 1.8s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_04_8k_16bit_DSP.tx MIP-COUNT[13685,2264,74,40,24,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 109 1 1 384.0 2.5s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Normal.1001_a.png UNTILED
04:05:55 8770MB | 110 1 1 64.0 0.6s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Roughness.1001_02.png UNTILED
04:05:55 8770MB | 111 1 2569 60.2 1m 52.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_crown_Gold_Normal.1001.tx MIP-COUNT[1500,734,244,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 112 1 4379 17.1 13.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_crown_Gold_Roughness.1001.tx MIP-COUNT[3024,1008,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 113 1 787 18.4 1m 11.4s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Normal.1001_b.tx MIP-COUNT[430,200,92,38,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 114 1 1355 5.3 4.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Roughness.1001.tx MIP-COUNT[720,352,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 115 1 11 0.3 0.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_rings_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 116 1 11 0.0 0.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_rings_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 117 1 880 13.8 0.2s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Oranges_01_DSP_8k_32bit.tx MIP-COUNT[214,192,200,190,62,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 118 1 29 0.7 1.3s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Oranges_Gold_Normal_1001.tx MIP-COUNT[0,0,8,8,4,2,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 119 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Oranges_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 120 1 4560 71.2 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/R_Shoe_DSP_8k_32bit.tx MIP-COUNT[3312,930,250,62,5,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 121 1 6838 106.8 2.8s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Ribes_01_DSP_8k_32bit.tx MIP-COUNT[3855,1866,779,253,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 122 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Ribes_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 123 1 3754 58.7 0.8s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Rings_DSP_8k_32bit.tx MIP-COUNT[2080,819,557,218,60,15,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 124 1 763 17.9 6.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Balconies_BaseColor.1001.tx MIP-COUNT[556,124,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 125 1 499 11.7 8.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Balconies_BaseColor.1002.tx MIP-COUNT[328,102,42,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 126 1 763 17.9 20.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Balconies_Normal.1001.tx MIP-COUNT[556,124,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 127 1 499 11.7 11.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Balconies_Normal.1002.tx MIP-COUNT[328,102,42,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 128 1 475 1.9 0.6s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Balconies_Roughness.1001.tx MIP-COUNT[192,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 129 1 427 1.7 0.7s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Balconies_Roughness.1002.tx MIP-COUNT[224,112,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 130 1 1159 27.2 29.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_BaseColor.1001.tx MIP-COUNT[826,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 131 1 1159 27.2 23.9s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_Normal.1001.tx MIP-COUNT[826,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 132 1 1003 3.9 2.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_Roughness.1001.tx MIP-COUNT[656,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 133 1 893 20.9 21.2s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Columns_BaseColor.1001.tx MIP-COUNT[626,184,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 134 1 893 20.9 14.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Columns_Normal.1001.tx MIP-COUNT[626,184,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 135 1 411 1.6 0.9s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Columns_Roughness.1001.tx MIP-COUNT[128,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 136 1 343 8.0 4.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_PavementInside_BaseColor.1001.tx MIP-COUNT[192,90,34,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 137 1 665 5.2 0.1s 2048x2048x1.u16 D:/_Projects/Mydas/Textures/Room_PavementInside_Height.1001.tx MIP-COUNT[644,21,0,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 138 1 343 8.0 3.8s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_PavementInside_Normal.1001.tx MIP-COUNT[192,90,34,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 139 1 427 1.7 1.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_PavementInside_Roughness.1001.tx MIP-COUNT[224,128,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 140 1 259 6.1 10.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_PavementOutside_BaseColor.1001.tx MIP-COUNT[140,60,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 141 1 259 6.1 8.7s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_PavementOutside_Normal.1001.tx MIP-COUNT[140,60,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 142 1 107 0.4 0.2s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_PavementOutside_Roughness.1001.tx MIP-COUNT[0,16,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 143 1 631 14.8 19.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Stone_Bench_BaseColor.1001.tx MIP-COUNT[386,158,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 144 1 633 14.8 8.7s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Stone_Bench_Normal.1001.tx MIP-COUNT[386,160,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 145 1 779 3.0 0.8s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Stone_Bench_Roughness.1001.tx MIP-COUNT[432,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 146 1 1109 26.0 13.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Walls_BaseColor.1001.tx MIP-COUNT[784,234,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 147 1 933 21.9 13.4s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Walls_Normal.1001.tx MIP-COUNT[640,202,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 148 1 697 16.3 22.8s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Walls_Normal.1002.tx MIP-COUNT[432,180,58,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 149 1 827 3.2 1.3s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Walls_Roughness.1001.tx MIP-COUNT[480,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 150 1 251 1.0 0.6s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Walls_Roughness.1002.tx MIP-COUNT[16,144,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 151 1 5344 83.5 2.0s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Table_DSP_8k_32bit.tx MIP-COUNT[2186,2188,733,203,33,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 152 1 61 1.4 5.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Table_Gold_Normal_DirectX.tx MIP-COUNT[8,20,4,10,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 153 1 203 0.8 1.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Table_Gold_Roughness.tx MIP-COUNT[48,64,16,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 154 1 1811 14.1 0.3s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Tablecoth_Gold_Height_02.tx MIP-COUNT[514,1024,256,17,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 155 1 619 2.4 1.9s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Tablecoth_Gold_Roughness.tx MIP-COUNT[240,192,112,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 156 1 3967 93.0 ( 16 0.4) 1m 43.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/schvfgwp_4K_Albedo.tx MIP-COUNT[2644,973,259,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 157 1 43 0.2 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/schvfgwp_4K_Roughness.tx MIP-COUNT[0,0,0,16,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 158 1 31 0.7 1.3s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Albedo.tx MIP-COUNT[0,10,10,4,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 159 1 31 0.7 1.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Normal_LOD0.tx MIP-COUNT[0,10,10,4,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 160 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 161 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 162 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 163 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 164 1 275 6.4 6.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Albedo.tx MIP-COUNT[4,14,170,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 165 1 275 6.4 4.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Normal_LOD0.tx MIP-COUNT[4,14,170,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 166 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 167 1 497 11.6 10.9s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Albedo.tx MIP-COUNT[72,198,144,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 168 1 497 11.6 14.2s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Normal_LOD0.tx MIP-COUNT[72,198,144,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 169 1 43 0.3 0.5s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Roughness.tx MIP-COUNT[0,0,8,8,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 170 1 7 0.2 0.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 171 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 172 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 173 1 133 3.1 3.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Albedo.tx MIP-COUNT[4,36,40,28,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 174 1 133 3.1 4.2s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Normal_LOD0.tx MIP-COUNT[4,36,40,28,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 175 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 176 1 7 0.2 0.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 177 1 7 0.2 0.0s 8192x8192x3.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 178 1 11 0.1 0.1s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Roughness.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 179 1 359 8.4 5.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Albedo.tx MIP-COUNT[174,114,44,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 180 1 652 10.2 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Displacement.tx MIP-COUNT[368,203,60,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 181 1 361 8.5 7.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Normal_LOD0.tx MIP-COUNT[176,114,44,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 182 1 11 0.1 0.0s 2048x2048x1.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 183 1 229 5.4 7.1s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Albedo.tx MIP-COUNT[116,76,18,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 184 1 777 12.1 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Displacement.tx MIP-COUNT[460,232,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 185 1 229 5.4 6.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Normal_LOD0.tx MIP-COUNT[116,76,18,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 186 1 11 0.1 0.0s 2048x2048x1.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 187 1 7 0.2 0.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 188 1 533 8.3 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Displacement.tx MIP-COUNT[286,162,63,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 189 1 7 0.1 0.0s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 190 1 11 0.0 0.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 191 1 7 0.2 0.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 192 1 945 14.8 0.2s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Displacement.tx MIP-COUNT[618,242,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 193 1 7 0.1 0.0s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 194 1 11 0.0 0.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 195 1 11 0.3 0.2s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Albedo.tx MIP-COUNT[0,0,2,2,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 196 1 580 9.1 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Displacement.tx MIP-COUNT[317,177,64,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 197 1 15 0.2 0.2s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Normal_LOD0.tx MIP-COUNT[0,0,4,4,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 198 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 199 1 11 0.3 0.5s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Albedo.tx MIP-COUNT[0,0,0,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 200 1 367 5.7 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Displacement.tx MIP-COUNT[185,103,57,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 201 1 15 0.2 0.6s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,4,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 202 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 203 1 125 2.9 1.4s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddlffshw_4K_Albedo.tx MIP-COUNT[0,70,30,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 204 1 433 6.8 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddlffshw_4K_Displacement.tx MIP-COUNT[215,135,61,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 205 1 155 1.8 1.5s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddlffshw_4K_Normal_LOD0.tx MIP-COUNT[0,88,40,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 206 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddlffshw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB |
04:05:55 8770MB | Tot: 206 267617 4520.5 ( 20 0.4) 28m 37.7s
04:05:55 8770MB | 2 not tiled, 2 not MIP-mapped
04:05:55 8770MB | Top files by bytes read:
04:05:55 8770MB | 1 384.0 MB ( 8.5%) 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Normal.1001_a.png UNTILED
04:05:55 8770MB | 2 170.8 MB ( 3.8%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Normal_DirectX.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 170.8 MB ( 3.8%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | Top files by I/O time:
04:05:55 8770MB | 1 3m 34.9s (12.5%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 2m 12.3s ( 7.7%) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1001.tx MIP-COUNT[1874,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 1m 52.1s ( 6.5%) 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Base_Color.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | Files with slowest I/O rates:
04:05:55 8770MB | 1 0.16 MB/s (0.04MB/0.27s) 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Apples_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 0.26 MB/s (18.45MB/71.39s) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Normal.1001_b.tx MIP-COUNT[430,200,92,38,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 0.28 MB/s (1.43MB/5.09s) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Table_Gold_Normal_DirectX.tx MIP-COUNT[8,20,4,10,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | (fastest was 155.6 MB/s)
04:05:55 8770MB | Top files by redundant I/O:
04:05:55 8770MB | 1 0.4 MB (87.3%) 4096x4096x3.f16 D:/_Projects/Mydas/Textures/schvfgwp_4K_Albedo.tx MIP-COUNT[2644,973,259,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 0.0 MB ( 3.6%) 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[322,211,67,22,6,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 3 0.0 MB ( 3.6%) 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2093,626,161,18,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | Broken or invalid files: 0
04:05:55 8770MB | -----------------------------------------------------------------------------------
04:05:55 8770MB | number of warnings, warning type:
04:05:55 8770MB | 1: %s%s: %s
04:05:55 8770MB | 1: %s: ignoring scaling component in camera matrix
04:05:55 8770MB | 2: [ass] line %u: %s.%s: unknown '%s' parameter
04:05:55 8770MB | 2: [ass] line %u: ignoring %s.%s (expected %u values for array type %s but found %u)
04:05:55 8770MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
04:05:55 8770MB | 1: [gpu] %s ("%s") not supported on the GPU
04:05:55 8770MB | 1: [imagers] forcing box filter due to usage of OptiX/OIDN imager
04:05:55 8770MB | 2: [mtoa] [%s] [node %s] Assigning temporary node id %i to associated Maya type name %s.
04:05:55 8770MB | 10: resetting parameter %s on %s (found: nans or infs)
04:05:55 8770MB | performance warnings:
04:05:55 8770MB WARNING | Scene creation time could be reduced slightly by fixing the following issues:
04:05:55 8770MB | 8 curves objects were motion blurred even though they were static.
Exporting Arnold Scene...
