Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
EXR compression in Arnold - fine tuning.
2 REPLIES 2
MrEddie
270 Views, 2 Replies
Hello there,
Just wondering if there are any unexposed settings in Maya to fine tune for example
EXR - dwaa compression. I see I can select it but the compression level is hidden. I assume it is set at 30 or so but if I wanted to squeeze the file size, is there anywhere to change this value ?
Thank you.
Alan.
@Stephen.Blair ?
2 REPLIES 2
shenmingY828V
in reply to: MrEddie
hi there, I recently trying to use DWAA compression type, and i found out by viewing the metadata in Nuke, the compression level is 45 by default i think... and i can't find a place to modify it in maya...And I have another problem... when i include some AOVs(cryptomatte,N,Z,....) the exr's metadata shows that it's actully using ZIP instead.... if someone can give me a hint...why is that....
yeah...well... I found it..... in mayaRenderLog.txt
00:00:12 1391MB WARNING | Cryptomatte cannot be set to dwa compression- the compression breaks Cryptomattes. Switching to Zip.
Technology Administrators
