Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Distance texture map
4 REPLIES 4
robw
584 Views, 4 Replies
I saw a guy using V-Ray Blend material in a iToo Forest Pack tutorial (below), he used a V-Ray Distance Texture map to set the blend materials' mask for a path on a ground surface.
Is there a way to do this using Arnold?
@4:10
https://www.youtube.com/watch?v=7B17VEFZyuQ
4 REPLIES 4
madsd
in reply to: robw
Yes.
Although the workflow is different.
You want to initialize a trace set.
I call mine "test"
Set AO traceset to "test"
Add a trace set closure in front of the material and call it "test"
Add an Arnold properties modifier to the Spline, and call "test" in traceset.
This way the spline is the only thing that picks up the mask, and as you can see the box is automatically excluded.
robw
in reply to: madsd
Got it - very good.
madsd
in reply to: robw
If the approach is working for you, consider flagging my post as solution.
thiago.ize
in reply to: robw
The just released Arnold 7.2.1 and associated plugins now have a distance shader.
https://arnoldrenderer.com/download/
Technology Administrators
