Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Correct usage of shadow_matte AOV in compositing package
1 REPLY 1
donat
488 Views, 1 Reply
The documentation about the shadow_matte AOV's is somewhat limited, in my opinion. (https://support.solidangle.com/display/A5NodeRef/shadow_matte)
aov_shadow
Direct light shadow AOV.
aov_shadow_diff
A difference AOV which can be used to eliminate the shadow from the direct component.
aov_shadow_mask
This AOV can be used in comp to localize and tweak the shadow.
Could you elaborate more on those and explain how those three AOV's should be used in a compositing program ?
Thanks in advance
Tags (1)
Labels (1)
1 REPLY 1
in reply to: donat
I know it's a very late answer .. but in order to separate the shadows from objects, I do this (using Photoshop):
layer with beauty:
RGBA ..and as mask >>> shadow.mask (inverted)
layer with shadows:
SHADOW.RGB ..and as mask >>> shadow.diff (set transparency on "multiply")
It works very well, also with foreground transparent object (like glass) covering the shadows on the ground 🙂 I use it for many renders showing metal machinery on white infinite backgrounds.
Technology Administrators
