Confussion how to use IOR in maya, and metalness
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, how are you? to see if someone can clarify some concepts that I have quite mixed and unfortunately I am creating many doubts, 1 .- I'm seeing in several tutorials that the metalness option is used to create specific metals, such as gold, chrome, silver etc, but the question that comes up is xq the IOR option is blocked when creating these metals ?? Whenever I want to create a metal, be it iron, steel, aluminum, I have to use the metalness option ?? and then the IOR ?? 2.- IOR theme I have reviewed several tutorials, and frankly I am bundled, some say that we do not follow the IOR lists that we find on the web, other ones on the refractive index page recommend you use those values, and I have also read that the IOR if we indicate it very high for example 30 does not have an actual effect and it is not recommended, ..... are the tables reliable? The refractive index page that is very complete is a reliable option? then to calculate the IOR of a metal and to be able to recreate it in Maya 2018 what guidelines should I follow to understand it? 3.- I tried to create the typical metal of an iron beam and I did not approach the minimum in any case, could someone help me? to understand this with an example or tutorial or book? I am very clumsy .. thank you and I feel the discomfort
