With no texture defined on the shape node via the mtoa_constant_difcol attribute I want the default texture to render instead, as described on this page:
https://docs.arnoldrenderer.com/display/A5AFMUG/Tokens
I can't get this to work. Is there a bug or is the example correct? I can't get either:
<attr:difcol default:/our_jobs_path/maya/sourceimages/1024_Testgrid.tx>
or
<attr:difcol default:/our_jobs_path/maya/sourceimages/1024_Testgrid>.tx
to work, the render is without a texture.
I tested it a bit. The default is used only if the user data attribute does not exist.
Using a full path as the user data didn't work. I had to put the path in the Texture Search Path, and the filename (without extension) in the user data or default
all the details about arnold tokens <attr> & <shapeName> here
https://www.youtube.com/watch?v=OtL7HMWyBPI
