Can I use aiRenderCurve and aiCurveWidth with operators on standins? I tried but ti didn;t seem to work. I currently have groups on curves listed as 1 curve shape in the standin hierarchy
Solved by Stephen.Blair. Go to Solution.
aiRenderCurve is not an Arnold parameter. It's a flag that tells MtoA whether or not to export the curves.
If you don't want to render the curves, set the curves.visibility parameter.
aiCurveWidth is curves.radius
but unless your curve width is constant, you have to write out an array of radius values, one for each point on the curve
Radius applies to both ribbon and thick
when setting the radius to an array to I create a custom operator? because selecting it from assignment menu creates a single flaot for radius
Hi
Sorry to hijack this thread but with regards to the Operator Assignment Expression for aiCurveWidth, curves.radius doesn't seem to work for me.
I have a SetParameter Operator linked to a StandIn Fur system that has been exported from Houdini and assigned a local override in which I would like to change the thickness of the fur via the override. I don't want to change the radius. Only the curve width/thickness.
The Operator is assigned as followed:
it's assigned to - /obj/ChrFur/Chr_Fur_Body/curves:3
the assignment[1] is - int curves.radius = 1
I've tried different values other than 1 and it doesn't do anything.
Also, can you elaborate on the process of adding various radius values for each point of the curve please?
Any help would be appreciated.
Darren is my colleague and I've taken over the problem he originally asked about, which is still not giving the required result when using the solution you gave earlier, so my question is a continuation of the original question.
Please advise if you still need me to make a new thread even if my question is related to the same thing and I will gladly do so.
There is no width, just radius.
A curve node has these parameters:
kick -info curves node: curves type: shape output: (null) parameters: 29 filename: <built-in> version: 6.0.1.0 Type Name Default ------------ -------------------------------- -------------------- BYTE visibility 255 BYTE sidedness 255 BOOL receive_shadows true BOOL self_shadows true BOOL invert_normals false FLOAT ray_bias 1e-06 MATRIX[] matrix (empty) ENUM transform_type rotate_about_center NODE[] shader (empty) BOOL opaque true BOOL matte false BOOL use_light_group false NODE[] light_group (empty) BOOL use_shadow_group false NODE[] shadow_group (empty) STRING[] trace_sets (empty) FLOAT motion_start 0 FLOAT motion_end 1 UINT id 0 UINT[] num_points (empty) VECTOR[] points (empty) FLOAT[] radius (empty) VECTOR[] orientations (empty) ENUM basis bezier ENUM mode ribbon FLOAT min_pixel_width 0 BYTE[] shidxs (empty) VECTOR2[] uvs (empty) STRING name
radius is an array of values, but you can set all values to the same thing, so radius = 1.0 will work
The selection expression must select the curves node.
The assignment is radius = 1.0
We managed to sort out the radius issue by using extremely small values.
The one thing I am curious about is that in Houdini, we're applying a width node which drives the tapering of the fur towards the tips of the fur. Is this perhaps controllable as a separate Operator as well or will the radius assignment control this as well or is it only controllable in Houdini before export for Maya?
