AOV not creating a layer in exr
timmport
timmport
I have been trying to get a depth layer by adding the Z AOV in my render settings. Once I add Z AOV I select the driver and then make sure merge AOV is checked. I render out in the exr format and while I get the beauty pass no z layer is generated. When I run Arnold render view I do have a z layer there. I tried the same with other AOV's and they also are not rendering. This is strange because I have never had any problems before. I am using a newer version of Arnold and I have noticed that the merge AOV field check box is now in a different place than it was for the previous version. The arnold documentation has not yet been updated to show the current new location for the merge AOV checkbox. I am using
MtoA 4.1.1
Arnold Core 6.1.0.0 watermarked version
Maya 2002.2 educational version
I also tried rendering out in the tif format. Maya generated a folder for a seperate z-depth file but did not actually render a z-depth image.
Stephen.Blair
Can you post an Arnold log?
https://docs.arnoldrenderer.com/display/A5AFMUG/Log
// Stephen Blair
// Arnold Renderer Support
timmport
Here is the log. Thanks in advance.
00:00:00 4332MB | log started Tue Mar 9 12:28:27 2021
00:00:00 4332MB | Arnold 6.1.0.0 [250260fb] windows clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.6.0 2020/10/27 10:53:09
00:00:00 4332MB | host application: MtoA 4.1.1 780b7bbf (master) Maya 2020
00:00:00 4332MB | running on 1900-WL-05025, pid=2432
00:00:00 4332MB | 1 x Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz (6 cores, 12 logical) with 65290MB
00:00:00 4332MB | NVIDIA driver version 431.45 (Optix 0)
00:00:00 4332MB | Windows 8 Enterprise Edition (version 6.2, build 9200)
00:00:00 4332MB | soft limit for open files is set at 2048
00:00:00 4332MB |
00:00:00 4332MB | loading plugin: C:/Program Files/Autodesk/Bifrost/Maya2020/2.2.0.1/bifrost/arnold-6.0.0.0/arnold_bifrost.dll ...
00:00:00 4332MB | arnold_bifrost.dll: bifrost_graph uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_object uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_multires_volume uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_multires_implicit uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_volume uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_points uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_implicit uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_polymesh uses Arnold 6.0.0.0
00:00:00 4332MB | arnold_bifrost.dll: bifrost_blocks uses Arnold 6.0.0.0
00:00:00 4332MB | loaded 9 plugins from 1 lib(s) in 0:00.00
00:00:00 4341MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:iron1F.defaultColor has no alpha component: exporting as RGBA
00:00:00 4344MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035314.defaultColor has no alpha component: exporting as RGBA
00:00:00 4344MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035315.defaultColor has no alpha component: exporting as RGBA
00:00:00 4344MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:steel1F.defaultColor has no alpha component: exporting as RGBA
00:00:00 4345MB | [mtoa] RGBA attribute grass_2_collection:file1.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:far24F1.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute Building_Construction:Building_Construction5.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute Building_Construction:Building_Construction11.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute grass_cylander:grass:file30.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute grass_cylander:grass:file31.defaultColor has no alpha component: exporting as RGBA
00:00:00 4346MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:stair2F.defaultColor has no alpha component: exporting as RGBA
00:00:00 4347MB | [mtoa] RGBA attribute ruins_fortress:file1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4386MB | [mtoa] RGBA attribute Building_Construction:Building_Construction3.defaultColor has no alpha component: exporting as RGBA
00:00:01 4387MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:far4F1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035332.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:tmt1F1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:tmt3F1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:Material__40F1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute tube_building:MapFBXASC032FBXASC03516_ncl1_2.defaultColor has no alpha component: exporting as RGBA
00:00:01 4388MB | [mtoa] RGBA attribute tube_building:MapFBXASC032FBXASC0352931.defaultColor has no alpha component: exporting as RGBA
00:00:01 4393MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035324.defaultColor has no alpha component: exporting as RGBA
00:00:01 4394MB | [mtoa] RGBA attribute Building_Construction:Building_Construction6.defaultColor has no alpha component: exporting as RGBA
00:00:01 4400MB | [mtoa] RGBA attribute Building_Construction:Building_Construction7.defaultColor has no alpha component: exporting as RGBA
00:00:01 4400MB | [mtoa] RGBA attribute Building_Construction:Building_Construction14.defaultColor has no alpha component: exporting as RGBA
00:00:01 4403MB | [mtoa] RGBA attribute bird_static:file1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4403MB | [mtoa] RGBA attribute bird_static:file2.defaultColor has no alpha component: exporting as RGBA
00:00:01 4403MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035317.defaultColor has no alpha component: exporting as RGBA
00:00:01 4403MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035316.defaultColor has no alpha component: exporting as RGBA
00:00:01 4405MB | [mtoa] RGBA attribute grove_01:scene_mesh_textured:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:01 4405MB | [mtoa] RGBA attribute grove_01:scene_mesh_textured:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:01 4405MB | [mtoa] RGBA attribute grove_01:scene_mesh_textured:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:01 4405MB | [mtoa] RGBA attribute grove_01:scene_mesh_textured:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:01 4470MB | [mtoa] RGBA attribute file6.defaultColor has no alpha component: exporting as RGBA
00:00:01 4470MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:slap2F.defaultColor has no alpha component: exporting as RGBA
00:00:01 4470MB | [mtoa] RGBA attribute file11.defaultColor has no alpha component: exporting as RGBA
00:00:01 4472MB | [mtoa] RGBA attribute file9.defaultColor has no alpha component: exporting as RGBA
00:00:01 4475MB | [mtoa] RGBA attribute tube_building:MapFBXASC032FBXASC03570_ncl1_1.defaultColor has no alpha component: exporting as RGBA
00:00:01 4477MB | [mtoa] RGBA attribute tube_building:MapFBXASC032FBXASC03592.defaultColor has no alpha component: exporting as RGBA
00:00:01 4477MB | [mtoa] RGBA attribute tube_building:MapFBXASC032FBXASC0352924.defaultColor has no alpha component: exporting as RGBA
00:00:01 4477MB | [mtoa] RGBA attribute fortress_wall:file1.defaultColor has no alpha component: exporting as RGBA
00:00:02 4622MB | [mtoa] RGBA attribute Building_Construction:Building_Construction1.defaultColor has no alpha component: exporting as RGBA
00:00:02 4624MB | [mtoa] RGBA attribute grass:file30.defaultColor has no alpha component: exporting as RGBA
00:00:02 4624MB | [mtoa] RGBA attribute grass:file31.defaultColor has no alpha component: exporting as RGBA
00:00:02 4644MB | [mtoa] RGBA attribute tree_oak2b:tree_oak2:Tree_Brunch_tile_dif_1.defaultColor has no alpha component: exporting as RGBA
00:00:03 4907MB | [mtoa] RGBA attribute Building_Construction:Building_Construction8.defaultColor has no alpha component: exporting as RGBA
00:00:03 4907MB | [mtoa] RGBA attribute Building_Construction:Building_Construction16.defaultColor has no alpha component: exporting as RGBA
00:00:03 4924MB | [mtoa] RGBA attribute sculp_collsus_of_rhoades:DiffuseFBXASC032Texture.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_09F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_011F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_013F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_015F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_017F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_019F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_11F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_13F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_15F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_17F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_19F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_21F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_23F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_25F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_27F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_29F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_31F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_33F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_35F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_37F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_39F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_41F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_43F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_45F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_47F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_49F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_51F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_53F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_55F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_57F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_59F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_61F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_63F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_65F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_67F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_69F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_71F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_73F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_75F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_77F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_79F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_81F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_83F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_85F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_87F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_89F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_91F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_93F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_95F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_97F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_99F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_101F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_103F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_105F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_107F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_109F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_111F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_113F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_117F.defaultColor has no alpha component: exporting as RGBA
00:00:04 4946MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_119F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5318MB | [mtoa] RGBA attribute Building_Construction:Building_Construction9.defaultColor has no alpha component: exporting as RGBA
00:00:06 5318MB | [mtoa] RGBA attribute Building_Construction:Building_Construction15.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_09F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_11F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_13F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_15F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_17F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_19F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5326MB | [mtoa] RGBA attribute green_construction:material_21F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5474MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:elev1F.defaultColor has no alpha component: exporting as RGBA
00:00:06 5481MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035318.defaultColor has no alpha component: exporting as RGBA
00:00:06 5481MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035319.defaultColor has no alpha component: exporting as RGBA
00:00:07 5489MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035306.defaultColor has no alpha component: exporting as RGBA
00:00:07 5489MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035307.defaultColor has no alpha component: exporting as RGBA
00:00:07 5505MB | [mtoa] RGBA attribute Building_Construction:Building_Construction4.defaultColor has no alpha component: exporting as RGBA
00:00:07 5563MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035311.defaultColor has no alpha component: exporting as RGBA
00:00:07 5563MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035312.defaultColor has no alpha component: exporting as RGBA
00:00:07 5573MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:elev7F.defaultColor has no alpha component: exporting as RGBA
00:00:07 5573MB | [mtoa] RGBA attribute steel_constuction_sized:Steel_construction:elev8F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_09F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_011F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_013F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_015F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_017F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_019F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_11F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_13F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_15F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_17F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_19F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_21F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_23F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_25F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_27F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_29F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_31F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_33F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_35F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_37F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_39F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_41F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_43F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_45F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_47F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_49F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_51F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_53F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_55F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_57F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_59F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_61F.defaultColor has no alpha component: exporting as RGBA
00:00:08 5652MB | [mtoa] RGBA attribute cam_const_pruned:scene_mesh_textured:material_63F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5834MB | [mtoa] RGBA attribute flowers:file5.defaultColor has no alpha component: exporting as RGBA
00:00:09 5834MB | [mtoa] RGBA attribute flowers:file10.defaultColor has no alpha component: exporting as RGBA
00:00:09 5853MB | [mtoa] RGBA attribute file7.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_09F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_11F.defaultColor has no alpha component: exporting as RGBA
00:00:09 5856MB | [mtoa] RGBA attribute n_STL_demo:scene_mesh_textured:material_13F.defaultColor has no alpha component: exporting as RGBA
00:00:10 6011MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035328.defaultColor has no alpha component: exporting as RGBA
00:00:10 6047MB | [mtoa] RGBA attribute tree_oak2b:tree_oak2:Tree_leaf_txtr_dif_v001_1.defaultColor has no alpha component: exporting as RGBA
00:00:10 6047MB | [mtoa] RGBA attribute tree_oak2b:tree_oak2:Tree_leaf_txtr_opc_v001_1.defaultColor has no alpha component: exporting as RGBA
00:00:10 6077MB | [mtoa] RGBA attribute scene_mesh_textured:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:10 6077MB | [mtoa] RGBA attribute scene_mesh_textured:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:10 6077MB | [mtoa] RGBA attribute scene_mesh_textured:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:10 6143MB | [mtoa] RGBA attribute little_rock_construction_2:scene_mesh_textured:material_115F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_01F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_03F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_05F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_07F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_09F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_11F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_13F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_15F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_17F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_19F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_21F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_23F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_25F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_27F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_29F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_31F.defaultColor has no alpha component: exporting as RGBA
00:00:19 7876MB | [mtoa] RGBA attribute N_stLouis_warehouse:material_33F.defaultColor has no alpha component: exporting as RGBA
00:00:21 8253MB | [mtoa] RGBA attribute sculp_collsus_of_rhoades2:DiffuseFBXASC032Texture.defaultColor has no alpha component: exporting as RGBA
00:00:22 8576MB | [mtoa] RGBA attribute tree_oak2b:tree_oak2:Tree_Main_dif_1.defaultColor has no alpha component: exporting as RGBA
00:00:22 8576MB | [mtoa] RGBA attribute tree_oak2b:tree_oak2:Tree_Main_bmp_1.defaultColor has no alpha component: exporting as RGBA
00:00:23 8619MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035320.defaultColor has no alpha component: exporting as RGBA
00:00:23 8629MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035322.defaultColor has no alpha component: exporting as RGBA
00:00:23 8631MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035326.defaultColor has no alpha component: exporting as RGBA
00:00:23 8631MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035327.defaultColor has no alpha component: exporting as RGBA
00:00:23 8654MB | [mtoa] RGBA attribute flowers:file6.defaultColor has no alpha component: exporting as RGBA
00:00:23 8654MB | [mtoa] RGBA attribute flowers:file9.defaultColor has no alpha component: exporting as RGBA
00:00:24 8694MB | [mtoa] RGBA attribute bull_dozer:MapFBXASC032FBXASC035330.defaultColor has no alpha component: exporting as RGBA
00:00:24 8781MB | [mtoa] RGBA attribute flowers:file3.defaultColor has no alpha component: exporting as RGBA
00:00:24 8781MB | [mtoa] RGBA attribute flowers:file12.defaultColor has no alpha component: exporting as RGBA
00:00:27 9077MB | [color_manager_syncolor] synColor version 2018.0.80
00:00:27 9077MB | [color_manager_syncolor] native catolog directory: C:/Program Files/Autodesk/Maya2020/synColor
00:00:27 9077MB | [color_manager_syncolor] optional custom catalog directory: C:/Users/tportlock/Documents/maya/synColor/Shared/
00:00:27 9083MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_16_map_Kd.tx"
00:00:27 9083MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_19_map_Kd.tx"
00:00:27 9084MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_01_map_Kd.tx"
00:00:27 9084MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_45_map_Kd.tx"
00:00:27 9088MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_56_map_Kd.tx"
00:00:27 9091MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_24_map_Kd.tx"
00:00:27 9095MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_06_map_Kd.tx"
00:00:27 9097MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_07_map_Kd.tx"
00:00:27 9100MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/ter1.tx"
00:00:27 9104MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_28_map_Kd.tx"
00:00:27 9107MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_12_map_Kd.tx"
00:00:27 9110MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_23_map_Kd.tx"
00:00:27 9119MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_floor_diff.tx"
00:00:27 9122MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_40_map_Kd.tx"
00:00:27 9125MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/adab.tx"
00:00:27 9128MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbgd.tx"
00:00:27 9133MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_04_map_Kd.tx"
00:00:27 9142MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/grove/modelThuJan09184223.232874/scene_mesh_textured_material_02_map_Kd.tx"
00:00:27 9149MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dpb.tx"
00:00:27 9152MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_32_map_Kd.tx"
00:00:27 9156MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_metall_diff.tx"
00:00:27 9158MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_15_map_Kd.tx"
00:00:27 9163MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_06_map_Kd.tx"
00:00:27 9166MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_11_map_Kd.tx"
00:00:27 9174MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_31_map_Kd.tx"
00:00:27 9177MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_52_map_Kd.tx"
00:00:27 9180MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_15_map_Kd.tx"
00:00:27 9188MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Documents/maya/projects/default/scene_castle/castle/scene_mesh_textured_material_01_map_Kd.tx"
00:00:27 9191MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_15_map_Kd.tx"
00:00:27 9207MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_05_map_Kd.tx"
00:00:27 9213MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_26_map_Kd.tx"
00:00:27 9226MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dfsd.tx"
00:00:27 9232MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_14_map_Kd.tx"
00:00:27 9245MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_fittings_diff.tx"
00:00:27 9250MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_05_map_Kd.tx"
00:00:27 9264MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_23_map_Kd.tx"
00:00:27 9270MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dtd.tx"
00:00:27 9290MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_46_map_Kd.tx"
00:00:27 9320MB | [AiMakeTx] maketx: no update required for "G:/download/tree_oak2/Textur/txtr/Tree_Main_dif.tx"
00:00:27 9343MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_27_map_Kd.tx"
00:00:27 9366MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dfd.tx"
00:00:27 9388MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_42_map_Kd.tx"
00:00:27 9429MB | [AiMakeTx] maketx: no update required for "G:/download/city_parcel/Building_Block_blinds3.tx"
00:00:27 9445MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_16_map_Kd.tx"
00:00:27 9459MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_05_map_Kd.tx"
00:00:27 9470MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_04_map_Kd.tx"
00:00:27 9479MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbad.tx"
00:00:27 9488MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_61_map_Kd.tx"
00:00:27 9497MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_44_map_Kd.tx"
00:00:27 9506MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_30_map_Kd.tx"
00:00:27 9515MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_54_map_Kd.tx"
00:00:27 9523MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_17_map_Kd.tx"
00:00:27 9531MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_33_map_Kd.tx"
00:00:27 9540MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_55_map_Kd.tx"
00:00:27 9549MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_60_map_Kd.tx"
00:00:27 9558MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_10_map_Kd.tx"
00:00:27 9568MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_35_map_Kd.tx"
00:00:27 9578MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_08_map_Kd.tx"
00:00:27 9587MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/C11.tx"
00:00:27 9594MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_1_opacity.tx"
00:00:27 9573MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_31_map_Kd.tx"
00:00:27 9547MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_09_map_Kd.tx"
00:00:27 9526MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_14_map_Kd.tx"
00:00:27 9498MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_foundation_diff.tx"
00:00:27 9476MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_28_map_Kd.tx"
00:00:27 9452MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_13_map_Kd.tx"
00:00:27 9428MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_08_map_Kd.tx"
00:00:27 9406MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_04_map_Kd.tx"
00:00:27 9415MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_scaffold_vertical_refl.tx"
00:00:27 9594MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_09_map_Kd.tx"
00:00:27 9595MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_4_opacity.tx"
00:00:27 9594MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_64_map_Kd.tx"
00:00:27 9574MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/grove/modelThuJan09184223.232874/scene_mesh_textured_material_01_map_Kd.tx"
00:00:27 9568MB | [AiMakeTx] maketx: no update required for "G:/download/barrier_concrette_02/BARRIER.tx"
00:00:27 9560MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_21_map_Kd.tx"
00:00:27 9552MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_07_map_Kd.tx"
00:00:27 9538MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_01_map_Kd.tx"
00:00:27 9532MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/Lead1.tx"
00:00:27 9526MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_58_map_Kd.tx"
00:00:27 9507MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/park_castle/scene_mesh_textured_material_02_map_Kd.tx"
00:00:27 9499MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_20_map_Kd.tx"
00:00:27 9483MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_59_map_Kd.tx"
00:00:27 9477MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_18_map_Kd.tx"
00:00:27 9471MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_wood_bar_diff.tx"
00:00:27 9463MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/red1.tx"
00:00:27 9448MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dpd.tx"
00:00:28 9389MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/steel11.tx"
00:00:28 9389MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_3.tx"
00:00:28 9389MB | [AiMakeTx] maketx: no update required for "G:/download/grass2/Maps/Grass1_diff.tx"
00:00:28 9389MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_10_map_Kd.tx"
00:00:28 9387MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_12_map_Kd.tx"
00:00:28 9379MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/W3.tx"
00:00:28 9373MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_fittings_refl.tx"
00:00:28 9365MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_53_map_Kd.tx"
00:00:28 9361MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/silo11.tx"
00:00:28 9349MB | [AiMakeTx] maketx: no update required for "G:/download/grass3/grass/grass/grass_bump.tx"
00:00:28 9337MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_11_map_Kd.tx"
00:00:28 9333MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/R1.tx"
00:00:28 9329MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/W1.tx"
00:00:28 9324MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/scaf1.tx"
00:00:28 9322MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/W4.tx"
00:00:28 9321MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_metall_refl.tx"
00:00:28 9319MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dtrd.tx"
00:00:28 9316MB | [AiMakeTx] maketx: no update required for "G:/download/bird_flock/uploads_files_1862971_Textures/LP.Pigeons_Diff.tx"
00:00:28 9312MB | [AiMakeTx] maketx: no update required for "G:/download/bird_flock/uploads_files_1862971_Textures/LP.Pigeons_OPA_mine.tx"
00:00:28 9304MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/grove/modelThuJan09184223.232874/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9301MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_33_map_Kd.tx"
00:00:28 9293MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/grove/modelThuJan09184223.232874/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9292MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_01_map_Kd.tx"
00:00:28 9303MB | [AiMakeTx] maketx: no update required for "G:/download/fortress_wall/Texture fortress wall/Fortress wall_DiffuzeMap_Complete.tx"
00:00:28 9307MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/MGL3315Panorama_hdr_15k.tx"
00:00:28 9308MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_36_map_Kd.tx"
00:00:28 9329MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_scaffold_vertical_diff.tx"
00:00:28 9334MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9350MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_01_map_Kd.tx"
00:00:28 9356MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_02_map_Kd.tx"
00:00:28 9371MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9377MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_06_map_Kd.tx"
00:00:28 9393MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_07_map_Kd.tx"
00:00:28 9399MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_09_map_Kd.tx"
00:00:28 9414MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_13_map_Kd.tx"
00:00:28 9420MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_18_map_Kd.tx"
00:00:28 9438MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_19_map_Kd.tx"
00:00:28 9444MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_20_map_Kd.tx"
00:00:28 9459MB | [AiMakeTx] maketx: no update required for "G:/download/city_parcel/Building_Block_concrete.tx"
00:00:28 9465MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_22_map_Kd.tx"
00:00:28 9469MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_25_map_Kd.tx"
00:00:28 9479MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_26_map_Kd.tx"
00:00:28 9487MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_29_map_Kd.tx"
00:00:28 9503MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_32_map_Kd.tx"
00:00:28 9509MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_34_map_Kd.tx"
00:00:28 9526MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_35_map_Kd.tx"
00:00:28 9531MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_37_map_Kd.tx"
00:00:28 9548MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_38_map_Kd.tx"
00:00:28 9554MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_39_map_Kd.tx"
00:00:28 9569MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_41_map_Kd.tx"
00:00:28 9575MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_43_map_Kd.tx"
00:00:28 9590MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_47_map_Kd.tx"
00:00:28 9596MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_48_map_Kd.tx"
00:00:28 9612MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_49_map_Kd.tx"
00:00:28 9617MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_50_map_Kd.tx"
00:00:28 9628MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_57_map_Kd.tx"
00:00:28 9632MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_51_map_Kd.tx"
00:00:28 9645MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_21_map_Kd.tx"
00:00:28 9649MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_63_map_Kd.tx"
00:00:28 9663MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_scaffold_horizontal_relf.tx"
00:00:28 9674MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_scaffold_horizontal_diff.tx"
00:00:28 9695MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9704MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_02_map_Kd.tx"
00:00:28 9722MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9728MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_04_map_Kd.tx"
00:00:28 9741MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_07_map_Kd.tx"
00:00:28 9747MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/green_spruce_street/scene_mesh_textured_material_08_map_Kd.tx"
00:00:28 9752MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit/Steel_Construction_maya/stag11.tx"
00:00:28 9755MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dcd.tx"
00:00:28 9760MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dcb.tx"
00:00:28 9763MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbud.tx"
00:00:28 9768MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbub.tx"
00:00:28 9772MB | [AiMakeTx] maketx: no update required for "G:/download/construction_kit_2/Building_Construction_territory_diff.tx"
00:00:28 9776MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbd.tx"
00:00:28 9779MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dbb.tx"
00:00:28 9784MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9787MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_02_map_Kd.tx"
00:00:28 9793MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9795MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_12_map_Kd.tx"
00:00:28 9801MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_05_map_Kd.tx"
00:00:28 9803MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_06_map_Kd.tx"
00:00:28 9808MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_09_map_Kd.tx"
00:00:28 9811MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_10_map_Kd.tx"
00:00:28 9816MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_11_map_Kd.tx"
00:00:28 9818MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_13_map_Kd.tx"
00:00:28 9823MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_14_map_Kd.tx"
00:00:28 9826MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_16_map_Kd.tx"
00:00:28 9831MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_17_map_Kd.tx"
00:00:28 9833MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_22_map_Kd.tx"
00:00:28 9838MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_24_map_Kd.tx"
00:00:28 9841MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_25_map_Kd.tx"
00:00:28 9846MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_27_map_Kd.tx"
00:00:28 9848MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_29_map_Kd.tx"
00:00:28 9852MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_30_map_Kd.tx"
00:00:28 9855MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_34_map_Kd.tx"
00:00:28 9860MB | [AiMakeTx] maketx: no update required for "G:/download/ruins_fortress/Texture ruins fortress four/Ruins fortress four_DiffuzeMap_Complete.tx"
00:00:28 9862MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/cam_construction/scene_mesh_textured_material_36_map_Kd.tx"
00:00:28 9865MB | [AiMakeTx] maketx: no update required for "G:/download/grass3/grass/grass/grass_color.tx"
00:00:28 9873MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9876MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_02_map_Kd.tx"
00:00:28 9880MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9882MB | [AiMakeTx] maketx: no update required for "G:/download/tree_oak2/Textur/txtr/Tree_leaf_txtr_dif_v001.tx"
00:00:28 9886MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Downloads/modelSatFeb20191013198948/scene_mesh_textured_material_06_map_Kd.tx"
00:00:28 9895MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Documents/maya/projects/default/sourceimages/TexturesCom_FloorsMarble0026_1_seamless_S.tx"
00:00:28 9900MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_1.tx"
00:00:28 9880MB | [AiMakeTx] maketx: no update required for "C:/Users/tportlock/Documents/maya/projects/default/scene_castle/castle/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9876MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/little_rock_revised/scene_mesh_textured_material_62_map_Kd.tx"
00:00:28 9868MB | [AiMakeTx] maketx: no update required for "G:/download/tree_oak2/Textur/txtr/Tree_leaf_txtr_opc_v001.tx"
00:00:28 9857MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_4.tx"
00:00:28 9852MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_00_map_Kd.tx"
00:00:28 9846MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_05_map_Kd.tx"
00:00:28 9842MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_01_map_Kd.tx"
00:00:28 9814MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_08_map_Kd.tx"
00:00:28 9802MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_03_map_Kd.tx"
00:00:28 9781MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_10_map_Kd.tx"
00:00:28 9761MB | [AiMakeTx] maketx: no update required for "G:/download/tree_oak2/Textur/txtr/Tree_Main_bmp.tx"
00:00:28 9737MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dhd.tx"
00:00:28 9728MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dtb.tx"
00:00:28 9707MB | [AiMakeTx] maketx: no update required for "G:/download/bulldozer_02/dshd.tx"
00:00:28 9715MB | [AiMakeTx] maketx: no update required for "G:/download/city_parcel/Building_Set7_main.tx"
00:00:28 9678MB | [AiMakeTx] maketx: no update required for "G:/download/flowers/textures/flowerbed_flowers_3_opacity.tx"
00:00:28 9472MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_04_map_Kd.tx"
00:00:28 9472MB | [AiMakeTx] maketx: no update required for "G:/photogrametry.1/N_stlouis_warehouse/scene_mesh_textured_material_02_map_Kd.tx"
00:00:28 9472MB | [AiMakeTx] maketx: no update required for "G:/download/sculpture_collosus/source/rodi_01/rodi_01_u1_v1-denoise-denoise.tx"
00:00:28 9085MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "aiAOVDriver1/driver_exr", "defaultArnoldDriver/driver_exr.RGBA"
00:00:28 9085MB WARNING | [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "aiAOVDriver2/driver_exr", "defaultArnoldDriver/driver_exr.RGBA"
00:00:28 9085MB |
00:00:28 9085MB | authorizing with default license managers: rlm, network, user ...
00:00:29 9089MB WARNING | rendering with watermarks because of failed authorization:
00:00:29 9089MB | [rlm] error initializing license system:
00:00:29 9089MB | [rlm] * Can't read license data (-102)
00:00:29 9089MB | [clm.v1] generic license checkout error (22)
00:00:29 9089MB | [clm.v2] SERVICE (4): this product has not been registered with the licensing service yet
00:00:29 9089MB | environment variables:
00:00:29 9089MB | ARNOLD_LICENSE_ORDER = (not set)
00:00:29 9089MB | ARNOLD_LICENSE_MANAGER = (not set)
00:00:29 9089MB | [rlm] solidangle_LICENSE = (not set)
00:00:29 9089MB | [rlm] RLM_LICENSE = (not set)
00:00:29 9089MB | [clm] ADSKFLEX_LICENSE_FILE = (not set)
00:00:29 9089MB | [clm] LM_LICENSE_FILE = (not set)
00:00:29 9089MB |
00:00:29 9089MB | [color_manager] using color manager of type "color_manager_syncolor"
00:00:29 9090MB | [color_manager] rendering color space is "scene-linear Rec 709/sRGB" with declared chromaticities:
00:00:29 9090MB | r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
00:00:29 8901MB |
00:00:29 8901MB | there are 4 lights and 2189 objects:
00:00:29 8901MB | 2 persp_camera
00:00:29 8901MB | 3 spot_light
00:00:29 8901MB | 1 skydome_light
00:00:29 8901MB | 217 image
00:00:29 8901MB | 1 utility
00:00:29 8901MB | 1 flat
00:00:29 8901MB | 173 lambert
00:00:29 8901MB | 42 standard_surface
00:00:29 8901MB | 11 bump2d
00:00:29 8901MB | 11 color_correct
00:00:29 8901MB | 4 uv_transform
00:00:29 8901MB | 1 maya_layered_shader
00:00:29 8901MB | 3 driver_exr
00:00:29 8901MB | 1 box_filter
00:00:29 8901MB | 1 gaussian_filter
00:00:29 8901MB | 1 closest_filter
00:00:29 8901MB | 2188 polymesh
00:00:29 8901MB | 1 list_aggregate
00:00:29 8901MB | 1 color_manager_syncolor
00:00:29 8901MB | 1 batch_progress_driver
00:00:29 8901MB |
00:00:29 8901MB | rendering image at 663 x 500, 3 AA samples
00:00:29 8901MB | AA samples max <disabled>
00:00:29 8901MB | AA sample clamp <disabled>
00:00:29 8901MB | diffuse samples 2 / depth 1
00:00:29 8901MB | specular samples 2 / depth 1
00:00:29 8901MB | transmission samples 2 / depth 8
00:00:29 8901MB | volume indirect <disabled by depth>
00:00:29 8901MB | total depth 10
00:00:29 8901MB | bssrdf samples 2
00:00:29 8901MB | transparency depth 10
00:00:29 8901MB | initializing 2665 nodes ...
00:00:30 8722MB | creating root object list ...
00:00:30 8722MB | node initialization done in 0:00.95 (multithreaded)
00:00:30 8722MB | updating 2666 nodes ...
00:00:30 8722MB | /aiSkyDomeLight1/aiSkyDomeLightShape1: skydome_light using 1 sample, 2 volume samples
00:00:30 8722MB | /spotLight3/spotLightShape3: spot_light using 1 sample, 2 volume samples
00:00:30 8722MB | /spotLight2/spotLightShape2: spot_light using 1 sample, 2 volume samples
00:00:30 8722MB | /spotLight1/spotLightShape1: spot_light using 1 sample, 2 volume samples
00:00:30 8722MB | scene bounds: (-371.789398 -95.6141205 -571.95697) -> (416.423798 148.422272 175.395416)
00:00:30 8722MB | node update done in 0:00.00 (multithreaded)
00:00:30 8722MB | [aov] parsing 2 output statements ...
00:00:30 8722MB | [aov] registered driver: "defaultArnoldDriver/driver_exr.RGBA" (driver_exr)
00:00:30 8722MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:00:30 8722MB | [aov] registered driver: "progress_driver" (batch_progress_driver)
00:00:30 8722MB | [aov] * "Z" of type FLOAT filtered by "progress_driver_filter" (box_filter)
00:00:30 8722MB | [aov] done preparing 3 AOVs for 2 outputs to 2 drivers (0 deep AOVs)
00:00:30 8723MB WARNING | [driver_exr] defaultArnoldDriver/driver_exr.RGBA: autocrop is only supported for non-tiled images, disabling on: C:/Users/tportlock/Documents/maya/projects/default/scene_castle/images/test_my_depth.exr
00:00:30 8724MB WARNING | [driver_exr] defaultArnoldDriver/driver_exr.RGBA: append specified, but output file "C:/Users/tportlock/Documents/maya/projects/default/scene_castle/images/test_my_depth.exr" is complete
00:00:30 8732MB | starting 12 bucket workers of size 64x64 ...
00:00:30 8732MB | render done in 0:00.000
00:00:30 8732MB |
00:00:30 8732MB | -----------------------------------------------------------------------------------
00:00:30 8732MB | scene creation time 0:28.88 machine utilization (11.31%)
00:00:30 8732MB | plugin loading 0:00.10
00:00:30 8732MB | unaccounted 0:28.78
00:00:30 8732MB | frame time 0:01.53 machine utilization (45.84%)
00:00:30 8732MB | node init 0:00.95
00:00:30 8732MB | sanity checks 0:00.31
00:00:30 8732MB | driver init/close 0:00.02
00:00:30 8732MB | unaccounted 0:00.56
00:00:30 8732MB | top session self-times by category
00:00:30 8732MB | worker waiting 0:00.52 (32.73%)
00:00:30 8732MB | InitializeNodes 0:00.41 (25.70%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.31 (19.91%)
00:00:30 8732MB | /little_rock_construction_2:scene_mesh_textured:Mesh/little_rock_construction_2:scene_mesh_textured:MeshShape 0:00.04 ( 3.01%)
00:00:30 8732MB | /Mesh4/Mesh4Shape 0:00.03 ( 1.93%)
00:00:30 8732MB | /Mesh6/Mesh6Shape 0:00.02 ( 1.75%)
00:00:30 8732MB | /Mesh5/Mesh5Shape 0:00.02 ( 1.75%)
00:00:30 8732MB | /Mesh/MeshShape 0:00.02 ( 1.69%)
00:00:30 8732MB | /N_stLouis_warehouse:Mesh/N_stLouis_warehouse:MeshShape 0:00.02 ( 1.27%)
00:00:30 8732MB | /group1/fortress_wall:fortressFBXASC032wallFBXASC032old/fortress_wall:fortresswalloldShape 0:00.01 ( 0.87%)
00:00:30 8732MB | /green_construction:Mesh/green_construction:MeshShape 0:00.01 ( 0.86%)
00:00:30 8732MB | /cam_const_pruned:scene_mesh_textured:Mesh/cam_const_pruned:scene_mesh_textured:MeshShape 0:00.01 ( 0.82%)
00:00:30 8732MB | /tree_oak2b:group1/tree_oak2b:tree_oak2:Tree_mdl:Tree_branch/tree_oak2b:tree_oak2:Tree_mdl:Tree_branchShape 0:00.01 ( 0.65%)
00:00:30 8732MB | /Mesh8/Mesh8Shape 0:00.01 ( 0.64%)
00:00:30 8732MB | /n_STL_demo:scene_mesh_textured:Mesh/n_STL_demo:scene_mesh_textured:MeshShape 0:00.00 ( 0.60%)
00:00:30 8732MB | /Mesh7/Mesh7Shape 0:00.00 ( 0.54%)
00:00:30 8732MB | node_init 0:00.18 (11.48%)
00:00:30 8732MB | /little_rock_construction_2:scene_mesh_textured:Mesh/little_rock_construction_2:scene_mesh_textured:MeshShape 0:00.02 ( 1.55%)
00:00:30 8732MB | /Mesh/MeshShape 0:00.01 ( 1.05%)
00:00:30 8732MB | /Mesh4/Mesh4Shape 0:00.01 ( 0.92%)
00:00:30 8732MB | /Mesh5/Mesh5Shape 0:00.01 ( 0.83%)
00:00:30 8732MB | /Mesh6/Mesh6Shape 0:00.01 ( 0.83%)
00:00:30 8732MB | /N_stLouis_warehouse:Mesh/N_stLouis_warehouse:MeshShape 0:00.01 ( 0.63%)
00:00:30 8732MB | /tree_oak2b:group1/tree_oak2b:tree_oak2:Tree_mdl:Tree_branch/tree_oak2b:tree_oak2:Tree_mdl:Tree_branchShape 0:00.01 ( 0.63%)
00:00:30 8732MB | initializeAllNodes 0:00.07 ( 4.95%)
00:00:30 8732MB | AiFree 0:00.02 ( 1.70%)
00:00:30 8732MB | top session self-times by node
00:00:30 8732MB | polymesh:/little_rock_construction_2:scene_mesh_textured:Mesh/little_rock_construction_2:scene_mesh_textured:MeshShape 0:00.07 ( 4.76%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.04 ( 3.01%)
00:00:30 8732MB | node_init 0:00.02 ( 1.55%)
00:00:30 8732MB | polymesh:/Mesh4/Mesh4Shape 0:00.04 ( 2.96%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.03 ( 1.93%)
00:00:30 8732MB | node_init 0:00.01 ( 0.92%)
00:00:30 8732MB | polymesh:/Mesh/MeshShape 0:00.04 ( 2.73%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.02 ( 1.69%)
00:00:30 8732MB | node_init 0:00.01 ( 1.05%)
00:00:30 8732MB | polymesh:/Mesh5/Mesh5Shape 0:00.04 ( 2.72%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.02 ( 1.75%)
00:00:30 8732MB | node_init 0:00.01 ( 0.83%)
00:00:30 8732MB | polymesh:/Mesh6/Mesh6Shape 0:00.04 ( 2.72%)
00:00:30 8732MB | polymesh:/N_stLouis_warehouse:Mesh/N_stLouis_warehouse:MeshShape 0:00.03 ( 2.01%)
00:00:30 8732MB | PolyMeshSanityCheck 0:00.02 ( 1.27%)
00:00:30 8732MB | node_init 0:00.01 ( 0.63%)
00:00:30 8732MB | peak CPU memory used 9900.20MB
00:00:30 8732MB | at startup 4323.43MB
00:00:30 8732MB | plugins 7.75MB
00:00:30 8732MB | framebuffers 8.25MB
00:00:30 8732MB | node overhead 1.44MB
00:00:30 8732MB | message passing 0.02MB
00:00:30 8732MB | memory pools 10.05MB
00:00:30 8732MB | geometry 2262.02MB
00:00:30 8732MB | polymesh 2262.02MB
00:00:30 8733MB | strings 24.25MB
00:00:30 8733MB | profiler 0.01MB
00:00:30 8733MB | unaccounted 3262.98MB
00:00:30 8733MB | -----------------------------------------------------------------------------------
00:00:30 8733MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:30 8733MB | lists 1 ( 0.0%) ( 0) ( 0.00, 0.00)
00:00:30 8733MB | polymeshes 2187 ( 0.0%) ( 0) ( 2262.02, 2262.02)
00:00:30 8733MB | geometric elements ( min) ( avg.) ( max)
00:00:30 8733MB | polygons 29428950 ( 1) ( 13456.3) ( 4757452)
00:00:30 8733MB | number of warnings, warning type:
00:00:30 8733MB | 1: [driver_exr] %s: append specified, but output file "%s" is complete
00:00:30 8733MB | 1: [driver_exr] %s: autocrop is only supported for non-tiled images, disabling on: %s
00:00:30 8733MB | 2: [mtoa] Two drivers produced the same output path. AOV merging is only supported using a single driver node: "%s", "%s"
00:00:30 8733MB | 1: rendering with watermarks because of failed authorization:
00:00:30 8733MB | performance warnings:
00:00:30 8733MB WARNING | Rendering CPU utilization was only 46%. Your render may be bound by a single threaded process or I/O.
00:00:30 8733MB WARNING | Scene creation was a significant amount of total time (95%). Consider optimizing this process first.
00:00:30 8733MB | [stats] wrote stats iteration 7 to file: C:/Users/tportlock/Documents/maya/projects/arnold_stats.1.json
00:00:30 8733MB |
00:00:30 8733MB | releasing resources
00:00:30 6171MB | Arnold shutdown
Stephen.Blair
Merge AOVs is enabled on two more more drivers, and that breaks everything:
Check the driver nodes:
// Stephen Blair
// Arnold Renderer Support
timmport
Hello All, and my thanks to Stephen and M. who messaged me. The solution was actually embarrassing but I thought I would post it here for future reference. After getting a message from M about the openExr photoshop plugin I downloaded it again. I've been using it for a long time but realized that my photoshop updates itself frequently. I suspect that in one of the recent updates the plugin must of stop working. I reinstalled the plugin and now it works fine. Thanks for helping me solve this.
