Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
aiMixShader question?
2 REPLIES 2
650 Views, 2 Replies
hi all,i testing the aiMiShader render test.i find the aiMixShader incerase more render time. Case 1.
  • object : 1000 cube
  • shader : aiStandardSurface1
  • light : skyDomeLight
  • AA Sample : 10
  • render time : 11:00min
Case 2.
  • shader : aiMixShader
    • shader1 : aiStandardSurface1
    • shader2 : aiStandardSurface1
    • Mix Weight : 0.5
    • Mix Mode : blend
  • AA Sample : 10
  • render time : 20:00min
my aiStandardSurface1 not connection other node Case 1 and Case 2 is same aiStandardSurface setting
So my question is, why aiMIxShader incerase more render time? And How to optimiza aiMixShader? Cheers, Sum
Labels (3)
2 REPLIES 2
My understanding is it would be running each shader separately and combining the results, so it makes sense it would double render time. What you can do instead is use the mix shader on inputs to a single standard surface, such as mixing the diffuse texture from several input sources before plugging them in.
maxtarpini
@Tim Harding at that point probably an aiLayerRgba is a better choice.
