Ai Toon Shader - Tonemap transitions?
MANIAKRA
MANIAKRA
Hello there!
Using the Ai Toon shader, I am trying to make a more 'interesting' transition between my ramp tones (colour boundaries) of the Base Tonemap (see attached). I am attempting to create a "rake" effect or noise of some kind.
My Question: Is this possible with the arnold ramp node?
I also found this guide which suggests that you can add a Texture to your Ramp colour "Selected Position" to create interesting transition effects, however, I am unable to achieve this result with this method.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Maya-Lig...
Any tips or suggestions are greatly appreciated. Thanks!
lee_griggs
Have you tried adding noise to the ramp? The Maya ramp has noise built in too.
Lee Griggs
Arnold rendering specialist
AUTODESK
