I'm wondering why alll arnold Light in Katana look like a point Light ? How can you guys aim or orient Quad Light since there is no direction?
There is limited support for viewer manipulators for lights in KtoA, but improvements are planned for this. However, most light types do have different icons and indicators in the viewer. Quad lights should show some information on size and the direction, for example. Can you provide more information on how you create your quad light in katana/ktoa?
# with Renderman activated
all arnold light share the same point_light icone, no shape, no direction
# Whitout Renderman
quad_light has a proper icone
spot-light has a proper icone
disk_light and distant_light share the same icone
skydome_light and photometric_light share the same "point_light" icone
# How I create a quad_light or any light?
In GafferThree hitting L or right cliking then choosing Light
Double click under Shader, a window popup let you pick up a light! but there is nothing in that list!
I have to right Click under Shader, add Shader/light, double clicking again, then all arnold light are listed
Then choosing the desired light! quad light for example!
if I add another light, I have to repeat the same operation to get all the light listed
# or after creating a light in GafferThree, add Shader under material then choosing Light, then pickup quad_light from arnoldLightShader.
# Reactivating Renderman:
Creating arnold light in GafferThree, if I double clic under Shader I get a list of Renderman light!
and all arnold light become broken! and sharing the same point_light icone!
