What is white spot on render images?
I have white spot on my render images, How I can remove them? I found solution on https://support.solidangle.com/display/A5AFMUG/Fireflies+-+Boat+Scene but not help.
The problem solve after I remove distant_light from a scenes But How I can keep distant_light on my scenes and remove white spot.
lee_griggs
Does the shader have specularity? If so, you could try increasing the Specular Roughness to see if that helps.
Lee Griggs
Arnold rendering specialist
AUTODESK
Yes, I have try already but doesn't work.
Thank Lee
