Using OpScript to set light links isn't working
huseila
huseila
Hi, I'm encountering a strange issue and I'm not sure if it's a problem with Katana or KtoA, so I've posted on both forums for help. I tried to set up a light link with OpScript, but it doesn't seem to work, and the attributes are behaving oddly. The 'offCEL' attribute only has a value set for the light I select, even though the OpScript is supposed to apply to both lights. However, even when the 'offCEL' attribute shows a value, the render result looks as if no light link was set up at all. I wonder if this is a bug or if I'm setting things up incorrectly. Any suggestions would be appreciated. Thanks.
tim.goransson6XTRC
I think you might have to set the lightList attribute under `/root/world` instead of directly on the lights. I recently did something similar when creating light filters with an opscript. I'd check the katana workflow forums but looks like they are down.
tim.goransson6XTRC
what I did was I made a user parameter on the opscript where I add the lights, then when you GetOpArg that param it will be one big string. so you will have to process the string to turn it into a table of light locations you can loop over to get the information you need for the light list
huseila
Hi Tim, thanks for the solution. It works when the opscript is applied on "/root/world". It required a slight adjustment to the code logic, but it definitely works.
