Updating path of vdb inside assfile
Daveborkiewicz_Daveborkiewicz
I have a bunch of smoke vdbs simulated in range 1001-2001 instanced on pointcloud.
I baked them all in ass file and include that in my lighting scene. If I bake them on frame 1001 filename path inside ass file is set to "volume/smoke.1001.vdb".
How can I target volume nodes inside ass procedural with operators and update frame in path to 1002,1003..etc?
I can target whole procedural like that: *.(@derived == 'procedural') but how to target nodes inside?
Any help would be greatly appreciated
Dawid
Stephen.Blair
Why not use Arnold path mapping?
https://arnoldsupport.com/2020/08/06/remapping-paths-at-render-time/
// Stephen Blair
// Arnold Renderer Support
Can I dynamically update paths on a frame by frame basis with this approach?
Judging by examples it seems more suitable for static remaps like switching between different os etc
Stephen.Blair
path mapping or string_replace, either way you're limited to using regular expressions to update the paths
// Stephen Blair
string_replace operator with this kind of selection expression '*.((@node == 'volume') and (name == '*volume*'))' works well. I thought I need to target procedural on which that expression runs but it seems that runs on entire scene sent to Arnold. Very cool, saved a lot of time on rebaking many 1000 frames caches.
